1966 Ford Crew Cabs
Old Jan 10, 2011 | 08:58 PM
rustworthy's Avatar
rustworthy
1966 Ford Crew Cabs
I was looking for an early model Ford Bronco and found this 66 Crewcab. The guy I got it from put it on GM truck frame that was stretched. Im not sure where Im going yet. The cab is rust free trough out the whole floor. BUT a tree fell against the passenger side between the 2 doors. not bad-not good. Im glad to own it but???? Im thinking of a Dodge Cummins running gear. Or back to the old Bronco!! any help guys???? call gary 210-246-2307 thanks
Old Jan 10, 2011 | 10:03 PM
Broomfieldbum's Avatar
Broomfieldbum
Rustworthy, The first piece of advice I would give is don't mention putting anything other than Ford running gear under a truck in this forum. There are a lot of Ford purists here, and you won't see many people suggesting you break away from Ford.
Old Jan 10, 2011 | 10:55 PM
Bill W's Avatar
Bill W
It's your Crew, Build it how you want it!
welcome to the forum.
Old Jan 11, 2011 | 12:01 AM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
If its on a streched frame I would make sure its adaqute to hold up to a cummins. Those things are heavy and so is there transmissions too.
Also you should think about 3500 suspension under the front.
Old Jan 11, 2011 | 07:54 AM
rustworthy's Avatar
rustworthy
oh Im 100% Ford myself!! I was looking at my neighbors 1964 f-600 as to the leaf springs in front and rear. Can you fit a power steering gearbox fairly easy on the ton and a half?
hylankyler
Jan 31, 2015 09:42 AM
Truck Guy99
Sep 13, 2014 05:23 PM
ThatFordGuy
1978 - 1996 Big Bronco
Feb 25, 2011 09:49 PM
lars915
Jul 30, 2003 12:33 AM
koto
Mar 11, 2001 02:14 PM
