noise in my engine.
Old Jan 10, 2011 | 05:37 PM
gray.matthew's Avatar
gray.matthew
noise in my engine.
i have a 99 F250 and a few weeks ago it started shutting off while i was driving. i was told to try changing my cam sensor and i did. now, after i changed the sensor their is a loud grinding/knocking noise. i had it towed to a shop and they said my sensor is fine its the torque converter. i towed it to a transmission place and after replacing the torque converter the noise is still there. and the transmission place thinks its coming from my engine. anyone know what it could be?
Old Jan 10, 2011 | 05:44 PM
megawatt00's Avatar
megawatt00
Where did you get the CPS from? Some of the aftermarket (Autozone etc) ones have been know to do some weird things to out engines
Old Jan 10, 2011 | 05:59 PM
bfife's Avatar
bfife
still plays with trucks
did they change the flex plate? a cracked flex plate will make some horrendous noises. did you reuse the same CPS mounting bolt? just a shot in the dark but could it be rubbing or hitting something inside the front cover?
Barney
Old Jan 10, 2011 | 06:39 PM
Kwikkordead's Avatar
Kwikkordead
Barney just stated what I was going to say.
Flex plate will make some horrible rattling noises at idle.
I don't know that you would be able to hear a CPS grinding itself away on the camshaft and still run, but anything's possible for a short time.
Old Jan 10, 2011 | 06:51 PM
F350-6's Avatar
F350-6
I'm with Jim. Seems like there was another thread not too long ago with similar issues. Just changed the CPS and had a bad rattle. I don't think they ever came back with a fix, but I'd guess it's an aftermarket CPS and it's affected the timing which is changing the combustion characteristics and sounding like a bunch of marbles in a coffee can.
Old Jan 10, 2011 | 07:17 PM
gray.matthew
the first shop checked my cam sensor and said they liked it and it isnt one of the problem after market ones. but thats the first i have heard of the plate. thanks alot and i will tell them to check it. and i did use the same mounting bolt that was on the old sensor. and the marbles in a coffee can sounds exactly like what i hear.
Old Jan 10, 2011 | 07:32 PM
F350-6's Avatar
F350-6
Where did you get your CPS?
I would hope a tranny shop that changed a torque converter would also be able to diagnose a cracked flex plate if that was the issue, but I guess you never know.
Old Jan 11, 2011 | 10:50 AM
gray.matthew
found problem
cracked fly wheel.
Old Jan 11, 2011 | 11:35 PM
carltonwebb's Avatar
carltonwebb
I would make transmission shop give me labor cost of removing transmission again. They should have caught that when they pulled the transmission.
Motsch788
Oct 15, 2014 09:28 PM
srauner
Jan 27, 2014 02:29 PM
bengineer
Jun 16, 2013 06:00 AM
Contingen-Sea
Sep 6, 2011 02:24 PM
sandmn1010
Jul 12, 2011 01:05 AM
