Grey Vacuum line
Old Jan 9, 2011 | 11:04 PM
strokingbeast's Avatar
strokingbeast
Grey Vacuum line
The grey vacuum line that is on the passenger side by the firewall where does it hook up. I noticed it was off this morning when looking for a air leak that i could hear while driving.
Old Jan 9, 2011 | 11:35 PM
SLUF681's Avatar
SLUF681
Is your heater working correctly?
Old Jan 10, 2011 | 12:09 AM
strokingbeast
i dont remember to be honest with you i was a little to worried about the noise to turn the heat on. Does the grey line in the engine deal with the heat?
Old Jan 10, 2011 | 12:21 AM
SLUF681's Avatar
SLUF681
It's my understanding that there are 2 hoses coming off the vacuum pump. 1 to the 4WD (if you have it) and 1 into the cab for heat. I may be wrong. Somebody will be along to correct me if I am. I was wrong once before!
Old Jan 10, 2011 | 12:26 AM
strokingbeast
yea i have been looking up stuff for the vacuum pump and all i find is the stuff for the hubs i do need to check up on that too. but right now my main concern is what that line is suppose to be hooked up to. and clean up the engine bay a little to figure out if there is a boost leak of some sort. Noise would go away during certain rpms.
Old Jan 10, 2011 | 12:31 AM
big poppa's Avatar
big poppa
Theres a vaccum line under the hood on the pass. side and that operates the heater core shutoff when you have the AC running and theres a bunch of vaccum hoses behind your glove compartment. To access those, take everything out of your glove and tilt your glove box down and you'll see where the hose's go to, there's a plastic piece that acts like a juction to vaccum the air where it needs to go , sorry, can't remember what that plastic piece is called. It might have unplugged from there. Are you sure your not mistaking the Exhaust Back Pressure Valve in your turbo?? It makes a shhhhh shhhh sound, its for aiding in the warmup of your truck, perfectly normal, it means the system is working.
Old Jan 10, 2011 | 12:42 AM
strokingbeast
i was thinking it was the exhaust back pressure valve, but i could hear it while driving, is there a vacuum line that controls that valve. Yesterday was the first time i have noticed the line was loose and first heard that noise.
Old Jan 10, 2011 | 01:05 AM
SLUF681's Avatar
SLUF681
It sounds to me like you are hearing the EBPV. Is your vacuum pump running constantly? Is it possibly a line to the windshield washer?
Old Jan 10, 2011 | 01:14 AM
strokingbeast
yes the vacuum pump is always running. I guess i got alot to look into in the morning. I just hope its not a boost leak right now. Only place i could fit soot was by the intake going into the heads. but all the boots seem pretty new so i will be looking into those as well. not been a good two months for me with this truck
Old Jan 10, 2011 | 01:26 AM
SLUF681's Avatar
SLUF681
If your vacuum pump is running constantly I would guess your heater is defaulted to defrost also. I'm thinking that your problem is the vacuum hose for the heater. Just thought of something else, too. Check to see if it's the hose going to the heater valve that shuts the water off to your heater core. Do a search and see if you can find a vacuum hose diagram.
TjBart
Jul 16, 2017 11:12 AM
Nicmike
Feb 18, 2017 10:05 PM
oldskool92
Apr 20, 2016 06:48 AM
petrovich79f250
Mar 17, 2014 07:59 AM
Randy777
Jun 7, 2010 10:21 PM
