Coolant Temperature Sensor. please help with part #
Old Jan 11, 2016 | 08:25 AM
Tugly's Avatar
Tugly
Going cheaper has been tried many, many, many, etc... times. The failure rate is so high that it is one of the primary causes of many "Help me" threads on the forum. There is a reason these things are expensive - proper construction methods and materials, quality control, the mark-up on that expensive part to stay in business to support the part in the event of failure. You are paying for a better part - and the support to back your play.
So... do you wanna wrench... or drive? Your call.
Old Jan 11, 2016 | 09:23 AM
Lex2002's Avatar
Lex2002
Originally Posted by Walleye Hunter
I bought a cheap one once and it didn't work. When it comes to sensors use Ford stuff or it will fail prematurely. And RiffRaff's price is cheaper than the stealership.
Well, FORD isn't making those sensors. Someone else is. Wish I knew who that someone else is. $40 is absurd.
Old Jan 11, 2016 | 10:14 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
What Tugly said, I have tried the cheap ones in the past when in a bind and it wasn't even worth the time to install. Go OEM and be done with it for another 15 years. I don't know why everyone thinks $40 for a sensor is so expensive when it works and when you figure the expected life only costs you about $2.50 or less a year, lol. If you want cheap by a Geo Metro
Old Jan 11, 2016 | 10:42 AM
Lex2002's Avatar
Lex2002
I wanna wrench AND drive on my own terms.
Thanks for your thoughts boys. Much appreciated.
Old Jan 11, 2016 | 12:04 PM
petrokiller's Avatar
petrokiller
Lex I put one on my truck late last year. Ended up at Autozone unfortunately. There is oil temp sensor and coolant temp sensor. The one you need is under $10 I think. Wish I had a part number for you.
Old Jan 11, 2016 | 12:18 PM
Lex2002's Avatar
Lex2002
Thanks petrokiller.
ROCKAUTO has a HEART next to the unit I list above. But just cause its popular...
Old Jan 11, 2016 | 12:44 PM
petrokiller
BWD WT763. Just found the box with old sensor in it.
Check it out online at Autozone I believe
Old Jan 11, 2016 | 12:58 PM
Lex2002's Avatar
Lex2002
Ah youre a good man. BORG WARNER must be the manufacturer. $13 delivered on AMAZON.
http://www.amazon.com/gp/huc/view.ht...SP308C5ZD4%2C1
$4 on ROCKAUTO wholesaler closeout
Old Jan 11, 2016 | 07:23 PM
petrokiller
Hope it works!
Old Jan 12, 2016 | 06:30 AM
Tugly's Avatar
Tugly
Originally Posted by Lex2002
I wanna wrench AND drive on my own terms....
Don't we all.
Old Jan 12, 2016 | 04:45 PM
Pikachu's Avatar
Pikachu
BWD is a Standard Motor Products brand.
Old Jan 12, 2016 | 05:01 PM
Lex2002's Avatar
Lex2002
Don't we all.
Tuggles...I also wanna date a supermodel.
Pikachu, I bet BWD = Standard Motor Products brand = Motorcraft coolant temp sensor, $9 versus $40.
Old Jan 12, 2016 | 05:22 PM
  #28
Pikachu's Avatar
Pikachu
That wouldn't surprise me one bit.
Old Jan 12, 2016 | 05:26 PM
  #29
Lex2002's Avatar
Lex2002
Do I get to date a supermodel too?
Old Jan 12, 2016 | 06:15 PM
  #30
Pikachu's Avatar
Pikachu
Let's ask Carol . . .
