wont start need help
Old Jan 9, 2011 | 05:54 PM
bogdan27us's Avatar
bogdan27us
i have 2003 f350 7.3l i have problem doesn't start when i turn key to start everything is dead just light go on but when i put on neutral its crank but doesnt start please help me
Old Jan 9, 2011 | 06:43 PM
big poppa's Avatar
big poppa
A little more info on your truck, auto or stick?? Welcome to FTE by the way..Could be that dreaded fuel bowl heater.
Old Jan 9, 2011 | 06:50 PM
87 F-150 I6's Avatar
87 F-150 I6
I would check fuses, fuel delivery, oil level, and make sure you're batteries are charged.
Old Jan 9, 2011 | 06:59 PM
bogdan27us's Avatar
bogdan27us
its automatic
Old Jan 9, 2011 | 07:00 PM
bogdan27us's Avatar
bogdan27us
fuel filter changed and charged batteries and oil level good havent checked the fuses yeat
Old Jan 9, 2011 | 07:07 PM
Muktown's Avatar
Muktown
So in park you turn the key you get nothing? Starter wont crank or anything? But in neutral the starter cranks? What lights come on? Do you get a wait to start light? How cold is it outside? Is there smoke out of the tailpipe when it does crank?
Old Jan 9, 2011 | 09:57 PM
bogdan27us's Avatar
bogdan27us
yes when on park i get nothing start light comes on then goes off and still dosent start and theres no smore from tailpipes but i will double cheack
Old Jan 9, 2011 | 10:51 PM
Fishin76's Avatar
Fishin76
Battery Corrosion!!!! Clean all your battery connections with corrosion neutralizer and a corrosion inhibitor. Change all the battery bolts/nuts to clean ones, and tighten well. I added a washer before the nut to provide extra clamping.
read my post, this just happen to me today!!
https://www.ford-trucks.com/forums/1...-solution.html
Old Jan 9, 2011 | 11:14 PM
big poppa's Avatar
big poppa
If that is the problem our Moderator Jim (MeggaWatt00) here, he's our electrical guru turned us on to a product called "Nolex". I haven't gotten it yet but it can be purchased at Lowes or Home-Depot I'm told, if thats your problem.
Old Jan 9, 2011 | 11:34 PM
SLUF681's Avatar
SLUF681
Hey Mike, if you're talking about what I think you are, it's Noalox. It's made by Ideal. You'll find it in the electrical aisle. White tube/bottle with a blue label.
Old Jan 10, 2011 | 12:15 AM
strokingbeast's Avatar
strokingbeast
you can always check to make sure your starter is still attached. happened to me last week.
Old Jan 10, 2011 | 10:12 AM
bogdan27us's Avatar
bogdan27us
my batteries have no corrosion
Old Jan 10, 2011 | 10:14 AM
bogdan27us's Avatar
bogdan27us
what is the for
Old Jan 10, 2011 | 10:40 AM
Ziggy.'s Avatar
Ziggy.
Originally Posted by bogdan27us
what is the for
They were suggesting it for preventing corrosion on the battery terminals.
From the sounds of it you are having trouble with the trans range sensor, although if it doesn't act the same every time I would look for some knicked wires in the steering column grounding out.
Is it not even trying to start or stumble at all? just crank over fast?
Have you taken the plug out of the top of the hpop to check to see if it is full? and check the oil level on the dipstick.
Do you know anyone around you with a scanner or AE that can look at your truck?
Old Jan 10, 2011 | 12:49 PM
bogdan27us's Avatar
bogdan27us
I GOT IT TO START THIS MORNING I JUST CHANGED FUEL FILTER BAND FOUND BLOWN FUSE NOW ITS ALL GOOD
THANK YOU VERY MUCH EVERYONE FOR ALL YOUR HELP
