I have a 6.8 liter Triton V 10 in my motor home. 21,000 miles and I ran the engine less than 2 weeks ago. No past problems.
Will not start today. Starter engages and the batteries are fine. Checked the fuel pump shut-off switch and it didn't require a reset.
Any thoughts or ideas would be appreciated!!
JBD
Where's it stored?
If you've happened to attract some rodents that like to chew wiring, they could have chewed through the crank position sensor's wiring. No CKP input to the PCM=no start.
JL
Thanks to you who responded!!
I'm not sure why, but the engine fired right up this morning? I winter in Baja Mexico and the rig has not moved for 2 months though I fire it up every week or so and let it run for about 10 minuets while I raise and lower the jacks and move the slide outs in and back out.. Fuel tank is full with Stabil and Sea Foam added.
You forum is great and I will be checking it out often. Thanks again, JBDJR
Well that rules out frozen stuff...Sometimes the fuel pump locks when its worn. When not used. Keep an ear to hear the pump come on for the 2 second with key on...
