Need torque specs for rearend
Cut and paste doesn't keep original formatting, but there's what's in the WSM:
Torque Specifications Description Nm lb-ft lb-in
Differential bearing cap bolt 105 77 —
Differential pinion shaft lock bolt 30 22 —
Oil filler plug 30 22 —
Rear brake hose 18 13 —
Differential housing cover bolts 45 33 —
Driveshaft bolts 112 83 —
Rear spring plate nuts 115 85 —
Differential ring gear bolts 150 111 —
Shock absorber bolts 90 66 —
Traction-Lok clutch gauge nut 6.7 — 60
Rear axle identification tag bolt 31 23 —
Brake backing plate nuts 62 46 —
Brake caliper retainer bolt 27 20 —
Brake line retainer bolt 6 — 53
Brake line junction block retainer bolt 18 13 —
Stabilizer bar-to-axle housing U-bolt nuts 48 35 —
LeoJr
12-31-2013 09:30 PM
