I bought front pads from Napa a few years back - the tabs that slide on the caliper spring clips were too wide causing the pass side to stick resulting in a bad pull to the right while braking. Ended up having to replace the pads again. Went with Wagner Ceram - been happy ever since
I got 87000 mi on my original Motorcraft fronts before I changed them. Had OEM pads again as a result of service life of originals. I've 90,000 mi on my rears and still going. I know Ed would be happy to give you a quote!
I just did front pads, easy job. Make sure you have a caliper compressing tool, makes life easier. also, get some slide pin grease and grease the heck out of them.
Step by step instructions...just what I was looking for. Thanks
Those instructions are good until the part( or lack of ) about removing the rear rotors. Make sure you have a BFG lying around or get a big *** Puller like i did and it worked great.
If you coat the back of the new rotors where they contact the hub w/ a thin film of anti-sieze they'll be easy to get off next time. I know all about the "BFG" req - one of my fronts required a bit of "persuasion" to get it to come off
Thanks...I sent them an email on their front and rear...looks like they are out for the moment.
Where did everyone get their EBC pads at...anyone know what size are our rotors on our trucks too?
I just ordered mine from autopartswarehouse.com I read in a thread that they are affiliated with one of our sponsors? Ordered on Thursday night. They sent a tracking number Friday late afternoon but tracking doesn't show that they have been picked up by Fedex yet. Price for the pair was the same as ebay and a few other places.
The issue is on the rears. Those " in-the-hat" parking brake shoes routinely hang up even when you back them off so sometimes they need some help.
Anyone know what size are our rotors? I was under the assumption there are different size out there, or even the correct part number for OEM rotors. Thanks
