Replacing fuel pump
Old Jan 8, 2011 | 12:16 PM
redman84's Avatar
redman84
Replacing fuel pump
I'm about to finally replace my fuel pump and have a few questions. Is it mandatory to put on new banjo washers? Also is it as straight forward as pulling everything, turning over engine by hand, out with old, in with new, and zip it up? A write up would be nice if anybody has one. Thanks advance
Old Jan 8, 2011 | 01:20 PM
Ken_C's Avatar
Ken_C
I did reuse my copper washers. unless theyre really mangled reuse them. check the banjo bolt fit to the new pump before you mount the pump since you can only turn the thing 1/1000th of a turn at a time. also get the pump tappet at top dead center to pull it. be real carefull sometimes the tappet likes to fall out the bottom of the pump and into the engine (not good) it really is out with the old and in with the new. its a good time to fully clean out the filter can (and replace the filter) since you will be removing it. tip it upside down and hose it out with gumout carb n choke cleaner is what i did.
Old Jan 8, 2011 | 01:49 PM
Copedawg's Avatar
Copedawg
I think the Cali models started in 97. If not and you find you have a Cali model look here: https://www.ford-trucks.com/forums/6...placement.html
Old Jan 8, 2011 | 01:51 PM
redman84's Avatar
redman84
Very cool. Thank you sir. Is the banjo bolt 1 1/4"? And how did you get the tappet dead center top?
Old Jan 8, 2011 | 01:55 PM
redman84's Avatar
redman84
Thanks for the link. Fortunately I do not have a cali model but the pump does stick under the pedestal a little anyway.
Old Jan 8, 2011 | 01:57 PM
Copedawg's Avatar
Copedawg
you'll get then. You will be fine. finer then frogs fur!
Old Jan 8, 2011 | 02:25 PM
makomark's Avatar
makomark
Just search this forum for "sam Miller" and you'll find several posts with his write-up.
I reused my banjo bolt washers (looked like soft steel, not copper) and you get a lot more than 1/1000th of a turn, at a time, on the banjo bolt. I got mine off and on with a stock caraftsman 1.25" combo wrench - no mod required.
Great time to overhaul the fuel bowl if due. At a minimum, change the hoses while its apart. 30R9 (?) rated hose is adequate and the "fuel injection" style clamps are much kinder to the hoses.
Old Jan 8, 2011 | 02:42 PM
redman84's Avatar
redman84
Awesome man. Thanks a ton. I've also got a fuel bowl kit ready to go on when I button it all back up. Thanks again men
Old Jan 10, 2011 | 06:41 PM
redman84's Avatar
redman84
Thanks guys!!! I got it done earlier today and it runs better than it ever has. I guess the pump had been going for a while. I didn't realize how much pedal id been giving redman lately. After the 5 speed swap and several mods a little fuel is all I needed. Feels like I chipped it today.
1968F100ShortBed
Bronco II
Jul 11, 2011 10:48 PM
C350CREW
17
Sep 27, 2010 11:18 AM
Michigan Rick
May 29, 2010 11:32 AM
44magnum
Modular V10 (6.8l)
Nov 27, 2008 10:35 AM
bassproguy07
Aug 20, 2006 09:13 AM
