It's a 1988 Bronco II and I just changed the high pressure fuel pump under the driver's seat. I got it all back together and a leak started at the output of the fuel filter, which is further up closer to the engine. So, I replaced the fuel filter and clips and now the leak is at the input to the fuel pump. Only one o-ring came with the new filter, so I tried putting it at this fuel pump inlet and I tried it without the o-ring and it leaks either way. Suggestions?
Cant help you there buddy. Ive never changed my pump on the BII. I did re-wire it tho Sunday morn. while it was still cool outside. been 108F here in texas last mth. had to run a new wire from 20amp breaker on rt fender to a switch under dash,,left side, then from switch to pump. PO mickey-moused a wire from ECM relay directly to the pump up over the tranny,,,arg. now I can just flip the switch and turn on the pumps..at least noone can start it now unless they know the procedure/switch location,,haha.I have other theft deterants anyway. hope you get it fixed and dont have a fire. I have a Helms book for reference,,better than that haynes book.
Thanks DFW, I was actually born in Arlington, TX. Just down from the new cowboys stadium location.
I figured out that you have to put thread tape on the screw on fitting on the new fuel pump or it leaks like crazy. This was not a fun job by any means. On your back with fuel and rust flakes everywhere and electric wires nearby. You're right, changing the fuel pump on these rigs is a fire waiting to happen.
Your welcome Shorty. I watched em build the new stadium,,that thing is huge,,nor a blocked view anywhere at a function. Ima bout 1mile from it west on randol mill and fielder road. yeah that plumbers tape is a must working on fuel, air and water lines...bout as handy as good ole duct tape. I went to some j/y's down near Mansfield today scrounging parts of value for my BII. got some goodies, sun visors, door rubber seals, wiring, maybe go back Wed morning early before it gets too hot. they dont open til 8 am or later for some reason. got my eyes on some nice seats out of a Ranger, Ill have to dye em but hay,,theyll be comfortable. my old ones are shot. later buddy.
