Break fluid removal
Old Jan 8, 2011 | 11:13 PM
SLUF681's Avatar
SLUF681
I'm pretty sure I used either 3/16 or 1/4 inch ID tubing.
Old Jan 9, 2011 | 12:09 AM
mechelement's Avatar
mechelement
I just use a jug or small bucket and ensure the tubing stays at the bottom by placing a rock or piece of steel over it in the bucket/jug. I bled my brakes by myself with this method. Some jumping in and out of the truck, checking the reservoir and fluid tubing, but it worked well.
Old Jan 9, 2011 | 01:57 AM
homesteader's Avatar
homesteader
Chris are you just flushing your system ?
Old Jan 9, 2011 | 10:00 AM
kupaa's Avatar
kupaa
Yep,I was about to add some fluid and notice that is was black so I figure I just change it. Plus I have a whole gallon in my closet.
Old Jan 9, 2011 | 10:24 AM
Kwikkordead's Avatar
Kwikkordead
I use the 2 man method at work, open bleeder and 2nd guy in cab of vehicle pumps the brake pedal until fresh fluid comes out the bleeder.
Hold the pedal to the floor on the final stroke, close the bleeder.
Refill the reservoir, move to the next wheel.
Old Jan 9, 2011 | 12:18 PM
homesteader
Chris since you have a gallon just start bleeding brakes from farthest from reservoir. Do it until you have about 1/4of the old fluid left....dont go to far with out checking it or air will get in. Then add new fluid that way most of the old fluid would be out. Then continue bleeding until fluid is clean. Move to next wheel . Badabing bada booong.
Old Jan 24, 2011 | 06:25 PM
Headviking's Avatar
Headviking
Does this method work even with ABS?
Old Jan 24, 2011 | 07:20 PM
Izzy351's Avatar
Izzy351
Or you can make your own "power" bleeder with a little fabbing skills...
rkloehn
Modular V10 (6.8l)
Nov 11, 2011 07:44 PM
JFUSION
Escape & Escape Hybrid
Mar 19, 2008 12:50 PM
krussell
Apr 3, 2005 12:17 PM
pissed off in mn
Dec 13, 2003 08:32 PM
