when i put the gas pedal to the floor in my truck the engine just revs up but doesnt shift until i let off the gas about half way. is this my trans going out on me? my engine is newly rebuilt
okay thanks, il be sure to check that. If i did have the E40D would it be the same problem? im not entirely sure which one i have, i just got the truck less than a year ago.
You need to know what trans you have, all three are completely different. If you can`t figure it out from what IDID posted then count the oil pan bolts on the trans. AOD will have 14 bolts, C6 will have 17bolts and the E4OD will have 20 bolts.
If you have the AOD and the TV cable is not properly adjusted or not connected you can quickly burn the trans up so you need to find out what trans you have.
