bronco fuel tank?
Old Jan 8, 2011 | 10:14 AM
nwebbe1079's Avatar
nwebbe1079
bronco fuel tank?
ive been rolling around the idea of using a fullsize bronco tank (32 gal) to replace the rear tank in my 86' (6.9, c6 4x4) but ive heard that the gassers have somekind of coating on the inside that will mix with diesel and contaminate the fuel. also are the sending unit's the same size? any info would help. has anyone ever done this?
Old Jan 8, 2011 | 10:57 AM
wreckinball's Avatar
wreckinball
i have F150 dual tanks from a gasser currently running my truck. They have been in for the almost two years i have owned it and the three prior years to my ownership. The PO did a F150 body swap and used some of the other components on top of a F350 chassis. I dont know about some kind of lining but lets just say it all works in mine. pretty sure it is 33, when i drained mine and cleaned it out then filled it, it was almost exactly 33, just a bit over.
Old Jan 8, 2011 | 12:34 PM
kenpobuck's Avatar
kenpobuck
It is the zinc coating that is used on the gasser tanks that wreak havoc on our fuel systems. I am running the single 33 gallon Bronco tank in mine (this is the single rear tank). I bought a cheap uncoated tank for mine. The senders are different in length due to the tank being about twice the hieght of a gasser/diesel tank. If you find a tank for a Bronco with the smaller (2 5/8" I think) sender hole you can use the plain sender with out the pump on it. This tank will also accept the early style low pressure intank pump wich was made for carbed engines and will run our diesels as well. They also make these tanks in a polymer (plastic) version. But I have heard that these can be prone to static charge build up and that could be a problem lol.
Old Jan 8, 2011 | 08:15 PM
huggyb1972's Avatar
huggyb1972
JBG sells them (plastic and metal) both my 89 uses the smaller bung my old 90 used the larger bung.the plastic tank seams good so far but the sender hold down looks a little cheesey
Old Jan 9, 2011 | 05:05 AM
nwebbe1079's Avatar
nwebbe1079
thanks guys that exactly what i needed
Old Jan 9, 2011 | 10:23 AM
wreckinball
only because i am totally unsure, what about zinc would wreak havoc on our systems. what would it do? how could it pass the filter?
edit, just did some reading, very odd reaction that can form a soupy paste and break down some of the diesel. Wow, never knew. A gasser to diesel swap would need to factor in new fuel tanks, unless the current ones are plastic. Either way, interesting. It had be guessing but when i thought about it, any issues would have arisen with the PO not with me. The reaction will corrode off the lining somewhat fast.
Old Jan 9, 2011 | 01:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
these guys sell the poly 33 gal bronco tanks as well.something you may want to look at:
Automotive Parts Network - Product Info Pages :: Auto Parts :: Plastic Gas Tanks :: Plastic Gas Tanks - Ford - iNeedParts.com
hdfe
Jul 14, 2016 02:05 PM
yomadmike
19
Jun 24, 2014 07:28 PM
IDIDieselJohn
16
Jan 2, 2013 07:46 PM
fordman75
Apr 2, 2012 08:10 PM
dakota-boy
Mar 12, 2010 05:49 PM
