91 F 250 4x4 u joint fix?
Hi my kid has a 1991 F250 4x4 with lockouts. Need to change the u joints in the front axle, how hard is this? I am a weekend warrior mechanic but have never tackled this before. Can we do it or should we conceded to a real mechanic?
The truck has 130,000 on a 460 CI automatic. Being young he is not concerned with mileage , plus it has a 6" lift and large wheels/tires.
How dependable are the engines/tranny's in these trucks?
He just got it and will be doing the general maintainence, anything else to do or get done when doing this?
Thanks
Robb
Thanks
Robb
If you've ever done a wheel bearing it's not much more work.
Pull off lockout,remove brake caliper, remove hub, remove spindle,and pull out axle.
Shouldn't take an hour to take apart the first time.
Like zxwut said, check,then grease or replace other parts, while it's apart, especiallly the little spindle bearing in the back of hub behind the grease seal, not usually mentioned.
Greatwhite94
01-22-2017 08:51 PM
Ford SD
03-31-2015 03:05 PM
Ford4X4ingboy
17
09-23-2014 01:37 PM
suzanne9273
1999 to 2016 Super Duty
21
05-01-2009 02:31 PM
MikeFlorida
05-13-2007 06:52 PM
