Sponsored by: Real Truck
Rivnuts pulled through on step bars
Old Jan 7, 2011 | 06:34 PM
bookpile's Avatar
bookpile
I have step bars that the rivnuts pulled through. I'm trying to think of the best way to reattach the brackets to the enlargened holes. So far the best idea I've come up with is drywall toggle bolts with thread locker on them. Anyone have any better ideas for me?
Thanks
Old Jan 7, 2011 | 08:33 PM
JKBrad's Avatar
JKBrad
Use a big ol' heavy duty zip tie and pull it tight with some vice grips.
If you don't want to invest in a rivet nut gun, maybe you could find a U-bolt that you could thread through there.
Old Jan 7, 2011 | 08:45 PM
gregerm's Avatar
gregerm
Rivnuts probably wont hold since the hole is elongated already Drywall bolt should work or maybe some type of concrete bolt like that.
Old Jan 7, 2011 | 11:06 PM
CraigOutdoors's Avatar
CraigOutdoors
I'd get some fender washers bolts and nuts. Those'll hold a lot more than toggle bolts. Don't get me wrong, I love toggle bolts, I use 'em a lot at work, but if I'm gonna be steppin on it, I want something a little bit stronger. See if the end cap on the tube will pop off so you can get the nuts in there. If not, then I wouldn't use less than 3/8" toggle bolts. I've got some of those holding down my toolbox on my bed and they're pretty strong.
NorEasterMA
Dec 5, 2015 07:40 AM
kevinfromwebb
Oct 4, 2015 06:54 AM
4x4falcon
Australia Chapter
May 8, 2015 07:41 PM
SVTDriver97
18
Aug 27, 2014 09:48 AM
wahoo
Aftermarket Products
Dec 27, 2004 06:21 PM
