C6 Shifting Problems
Old Jan 7, 2011 | 03:06 PM
Hickfied's Avatar
Hickfied
Just done a headgasket job on my truck, and now my transmission will not change gears until 5000 RPM. Could this just be a major vac leak to the mod valve or have I left some linkage unhooked?
Old Jan 7, 2011 | 04:41 PM
Action4478's Avatar
Action4478
Are all the vac lines in the right places ?..Did you remove the kick down linkage ?
Old Jan 7, 2011 | 04:51 PM
Hickfied's Avatar
Hickfied
...What kickdown linkage? This truck didn't have it when I got it.
Old Jan 7, 2011 | 11:54 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sounds like the vacuum modulator line is disconnected.
Josh
Old Jan 8, 2011 | 12:48 AM
DKW 86's Avatar
DKW 86
There is a lever on the drivers side of the tranny for the kickdown feature.
There shoulkd be a rod going from the carb linkage on the driers side, at the rear of the linkage, that connects to the transmission.
Sounds like that lever is stuck down.
Old Jan 8, 2011 | 02:08 PM
Bullitt390's Avatar
Bullitt390
The kickdown has nothing to do with it, whether it is in the neutral postition or in the "kick-down" position.
The vacuum modulator is not seeing an adequate amount of vacuum, either because it is disconnected or there is a massive manifold vacuum leak.
Josh
Old Jan 8, 2011 | 03:41 PM
Action4478's Avatar
Action4478
Josh
I have had this happen to me , it is possible if he has one ...
The trans will governor shift ...
Old Jan 8, 2011 | 03:49 PM
duste's Avatar
duste
Since you were working around the vacuum line for the modulator valve, check to make sure it was reconnected on the intake. Also check the steel section of the line going to the valve, mine was rotten under one of the clamps that hold it to the transmission, the truck ran like crap and would not upshift into drive till 50mph .
Old Jan 8, 2011 | 04:45 PM
Bullitt390's Avatar
Bullitt390
I drove a C6 for over 100,000 miles without a kickdown.
A kickdown isn't needed and won't effect the shifting like what he is experiencing.
Josh
Old Jan 8, 2011 | 04:56 PM
Action4478's Avatar
Action4478
Josh
If the kick down linkage is stuck down , the trans will stay in first till it governor shifts .The symptoms are the same as no vacuum to the modulator .... What does that have to do with you not having one ?
Old Jan 8, 2011 | 05:27 PM
Bullitt390's Avatar
Bullitt390
If the kickdown is wired or stuck in the "engaged" position the tranny would shift 1-2-3 like normal during normal driving. I tried it several years ago thinking I would get firmer shifts and it did absolutely nothing.
If the engine speed and road speed dictates from a standing stop higher line pressures the governor, modulator, servo and VB are in control, kickdown does nothing.
The symptons are nowhere near the same and quit making the OP chase at nothing.
Josh
Old Jan 8, 2011 | 05:32 PM
Action4478's Avatar
Action4478
OK ........Except the trans is mechanical . The story of you trying to inprove yours by wiring ,just shows you don't have a clue what you are talking about ...
Old Jan 8, 2011 | 06:19 PM
Bullitt390's Avatar
Bullitt390
Wiring i.e. using bailing wire, a zip tie, etc. to manually keep the kickdown lever in the ENGAGED position.
I didn't think I would have to explain such simple things like I am talking to a 5 year old. Scratch that, a 3 year old, the 5 year would have understood.
Josh
Old Jan 8, 2011 | 06:40 PM
Action4478's Avatar
Action4478
I know your type . Can't convince based on facts ,resort to personal attacks .
If the trans is forced to stay in first gear , it will governor shift , period . Driving a hundred thousand miles without a kick down linkage is not proof of your argument. . I had the same problem once , the linkage was the problem . I also had a modulator vacuum problem ..I was trying to help OP . You were more concerned with something else ....
Maybe your ego ?......
Old Jan 8, 2011 | 06:50 PM
Action4478's Avatar
Action4478
Josh
Aside from the personal attack & the obvious BS. Explain to me how the trans would know to shift ,if it was commanded to stay in first ...
