Pacer overcab lights
Old Jan 7, 2011 | 11:06 AM
Duck Hunter81's Avatar
Duck Hunter81
Got some new overcab lights from pacer for xmas. I know that there is a connector in the RH kickpanel that has power for these lights but I was wondering if anyone knew which wire it was. If noone knows I will test and post the results but I thought I might be able to save a couple minutes of testing if someone already new. I have motorhead's website for the light install but he used the factory ford harness.
Old Jan 7, 2011 | 12:32 PM
just another truck's Avatar
just another truck
Per my print.. Brown.. per my memeory.. no clue.. that was a while back..sorry, but the print says brown.
Old Jan 7, 2011 | 12:40 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Originally Posted by just another truck
Per my print.. Brown.. per my memeory.. no clue...
Now that's funny. Thanks for the laugh Pat and I've been there buddy.
Old Jan 7, 2011 | 04:14 PM
kellens's Avatar
kellens
Hey I"m looking into getting some pacer cab lights and was hoping you can answer a question I have. Is the bottom of the lights flat? I know they are slightly curved but what I'm asking is if there are any studs molded into the light housing (like the ones they sell at napa) or is there a plastic wire harness connector hanging down (like on the oem ford lights). Reason I'm asking is because I have already installed recon led cab lights a couple years ago and they are now leaking so I'd like to replace them with pacer units but don't want to have to drill and paint any more holes in my roof.
On my truck (OBS) I found the plug for cab lights behind the passenger side plastic kick panel thing beneath the A-pillar. It was a brown plastic 2 contact connector and I'm not sure what the colors the wires were. Its pretty easy to find though as it was one of the few things not connected to anything .Good luck on the install!
Old Jan 7, 2011 | 04:27 PM
SpringerPop's Avatar
SpringerPop
Originally Posted by Duck Hunter81
I know that there is a connector in the RH kickpanel that has power for these lights but I was wondering if anyone knew which wire it was. .
Here's that connector:
http://springerpop.net/F350/images/c...s/DSC00245.jpg
Pop
Old Jan 7, 2011 | 04:48 PM
Duck Hunter81
The bottom of the lights are flat. They have a foam seal that is used between the cab and the light and I didn't see anything that stuck out past that. I would think that they would be a really easy install and could cover up your recon light holes that you can't use with them. I will try and take some pics of them tonight and post them later.
Old Jan 13, 2011 | 12:33 PM
kellens's Avatar
kellens
Thanks for the info, sounds like they will work just fine for me. If you get a chance to put up some pics it would be greatly appreciated. Thanks again!
Old Jan 13, 2011 | 12:38 PM
riverrat41's Avatar
riverrat41
I have Recons and I ran a true ground wire and tied all the hots together.The hot wire is tied into the running lights on the drivers side.Eventhough they do have the foam seal I used a little clear rtv as well.
1974F26
77
Nov 3, 2017 11:48 AM
fordmotorsports1
Apr 4, 2017 07:00 PM
2FordTrucks
Ford Truck Parts for Sale
Mar 1, 2017 03:19 PM
Jeff64F100CrewCab
All Things Towing
Dec 17, 2016 09:48 AM
'75HB250
26
Mar 10, 2016 02:29 PM
