Got up this morning and it was about 35* out, put my key in, waited for the WTS light to turn off, tried to crank and nothing, no slow crank or hesitation, didn't even hear the start solenoid click, it did it again when I left the bank, which is only about a 5 mile drive, but when i left home and came back from getting lunch it didn't do it, any suggestions as far as what it could be?
AUTO TRANS????? If so make sure its in P wiggle the shifter around might even try shifting to N and trying it> Mine is doing this right now
It was in P, I shifted down to low then back up to park to make sure it was, then after cycling the key 5 or 6 times when i left home it started just fine, but the 5 times i cycled it, it didn't make any attempt to start, and then when I left the bank it took 2 failed attempts to start, could it be the starter solenoid?
I just put a starter on too if it is the starter go with a good gear reduction starter made a huge difference my old one was the original 268000 miles on it guess it was time lol still worked just week in the winter
