Radio removal
Old Jan 28, 2026 | 01:40 PM
hepkat63's Avatar
hepkat63
6th Gear
single din to double din?
Hi all,
sorry to dig this thread up again - however, I found it VERY useful! I have only just purchased my 2002 F250 XLT. It has a single DIN radio/CD player in it - that works fine. However, due to the hundreds of cassettes I have (yes, I'm that old), I'd like to swap it out for a cd/cassette/radio. There are plenty online (ebay etc), however it is of course double DIN. Am i correct in assuming I can swap these straight out (removing existing single din radio and 'shelf' underneath) and that the plug that connects to single din radio , speakers connections etc are the same? Just trying to do research before I proceed. thank you.
Old Jan 28, 2026 | 04:41 PM
uglypitbull's Avatar
uglypitbull
You might have to do a little trimming if you are putting in a double din. As far as the harness/connecter goes, the brand of radio dictates the cable that attaches from the radio to the harness/connecter (usually comes with the radio).
Just look for a radio harness for your model of truck...prob the same for all years 99-2003. Crutchfield is pretty helpful with that.
Old Jan 28, 2026 | 05:36 PM
hepkat63's Avatar
hepkat63
6th Gear
thank you.
Old Jan 28, 2026 | 10:28 PM
INFRNL's Avatar
INFRNL
I'm pretty sure these trucks only came from the factory with a double din unit, no? If it has a din unit, it was probably replaced. If this is true, then you could just remove the install kit and go back to stock.
MRCSUSN2007
Jan 10, 2014 08:14 AM
dfooch
Aug 24, 2010 10:25 PM
PSWP
2004 - 2008 F150
Jun 21, 2008 05:24 PM
BullWapiti
Nov 10, 2005 12:44 AM
BullWapiti
Oct 26, 2005 12:35 PM
