Radio removal
Old Jan 7, 2011 | 11:05 AM
RobertJohn's Avatar
RobertJohn
Question Radio removal
As per my signature I've got an early '99.
How hard is it to remove the radio ? It is the stock one.
I'm hoping I don't have to pull the dash or crawl under the dash to do this.
Thanks
Old Jan 7, 2011 | 11:17 AM
woodnthings's Avatar
woodnthings
Easy deal, just go to the auto parts store or a stereo shop and buy a Ford Radio Removal tool, should be under $5. Insert them into the two holes on each side of the radio to un-lock the catches, it will then slide right out.
Old Jan 7, 2011 | 12:51 PM
rbaker6336's Avatar
rbaker6336
Not always,I have one I can't get out
Old Jan 7, 2011 | 01:39 PM
bobbyrjw's Avatar
bobbyrjw
If the radio removal tools don't work, this will get it out.
Old Jan 7, 2011 | 01:52 PM
superduty4x4's Avatar
superduty4x4
Yahtzee. Makes it a piece of cake.
Old Jan 7, 2011 | 04:26 PM
429 f-100's Avatar
429 f-100
once in all the way in gotta push out ea one to the outside then it should slide out. wes
Old Jan 7, 2011 | 04:31 PM
SpringerPop's Avatar
SpringerPop
Put the wire "tools" through the face of the stock radio, and firmly seat them at the bottom of the holes as shown in this photo (CLICK HERE), pull each tool away from each other, and pull slightly out.
The radio should come out.
Pop
Old Jan 7, 2011 | 06:20 PM
rbaker6336's Avatar
rbaker6336
I've never felt a bottom to the holes.I finally gave up after a few years of trying,figured if I ever really needed it out I may do some drilling or sawing.The empty hole might be good to put something in
Old Jan 7, 2011 | 06:52 PM
superduty4x4
If you need to get it out you can just pop the dash panel off and figure out what is going on then slide the radio out.
Old Jan 7, 2011 | 08:03 PM
Want-A-Be 7.3's Avatar
Want-A-Be 7.3
I had to do just what Superduty4X4 just said, the retainers had sprung out farther then the tool could push in. I fixed the retainers and reinstalled it correctly for the next need.
Old Jan 7, 2011 | 08:59 PM
SpringerPop
Actually, you can't. At least not without breaking that part of the plastic dash panel. There are two screws in the top of the radio hole that must be removed first, before the dash panel can come out.
See this photo to explain:
http://springerpop.net/F350/images/upfitter09.jpg
Pop
Old Jan 14, 2011 | 11:02 AM
Mike F250's Avatar
Mike F250
Does the stock radio need to come out to get the F650 dash in?
Can I make the radio removal tools outta heavy gauge wire?
Old Jan 14, 2011 | 11:20 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
No
Yes.
One thing I have found out about using the tools is that if you push them
in to far they won't depress the locking tabs enough to remove radio.
Certainly something you need to know if you make the tools yourself
because the OTC tools are tapered and notched.
I marked mine with tape.
By pushing them both outward the tabs depress.
Old Jan 14, 2011 | 12:26 PM
rbaker6336's Avatar
rbaker6336
God info
I thought there was a specified depth but I couldn't find it.I am gonna try the tape trick if I can still find my removal tools
Tried to rep you but still have to spread some more around
Old Jan 18, 2011 | 02:05 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
God info
First time I used the removal toos the radio popped right out. The second time it was a struggle and that is when I realized I was pushing the tools in too far. Trial + Error = Experience.
