Removing Corner Lights
Old Mar 6, 2003 | 12:34 PM
criszimmerman's Avatar
criszimmerman
How do I remove my corner lamps in the front to replace the turn signal bulb?
(Edited by Moderator for all caps)
Old Mar 6, 2003 | 01:45 PM
CobraXP's Avatar
CobraXP
If you are talking about a '95+, you need to lift the hood and there will be a flip on each side above the headlights. Flip it up and remove the two phillips screws. Then you will be able to pull the light housing put...
Old Mar 29, 2003 | 09:08 PM
dcook's Avatar
dcook
Question Removing Corner Lights
I am having the same issue. I have a '96 Explorer and I replaced a reverse light as well as a brake light with no problems, but I cannot figure out how to replace the front upper corner signal light. I flipped up the panel over the lights and removed the two screws that apeared to secure the light housing, but nothing will budge. Also, the front grill appears to be secured over top of the headlamp assembly, so I am not sure how I would get the headlamp assembly out even if I did get it loose.
IS there any document to go to on the WEB that may detail this lamp replacement?
Thanks,
David
Old Mar 30, 2003 | 12:07 AM
ford_tr_man's Avatar
ford_tr_man
just pull it will come out you just have to put out
yes its only the 2 screws that hold the light in you don't have to unscrew the grill
624WD
Jan 28, 2014 06:46 AM
WarX
Dec 24, 2013 10:19 PM
F100man
Jun 12, 2013 07:20 AM
jmbaker3
Feb 14, 2009 09:10 PM
CPerry
1997 - 2003 F150
Mar 24, 2004 08:59 AM
