All right fellow body work enthusiasts. I am curious if anybody has used a tumbler for small parts and bolts. I have seen them on the Eastwood site, and while I typically do not subscribed to all of their stuff as being as great as they do, I am curious if these tumblers are worth the investment. Thanks for any feed back.
I actually got one for Christmas from the wife. If I have time, I'll try it out this weekend, and let you know. It's from Eastwood also. I've had pretty good luck with their stuff so far.
I bought a cheaper one from HF and used it on my last restore but I broke it before I started on this one. I think they work great if you have the time. I had to run the few parts that would fit in the bucket for at least 24 hrs. But when they come out, blow them off, wipe em down and paint. Oh ya it is a little noisy too.
We used one daily at a boat company I worked for years ago. We would put small parts in it that were sheared and had sharp edges, they would come out with nice smooth edges 4 - 5 hours later.
So, with the unbelievable amount of body bolts I need to clean, this is a better option then standing next to the blasting cabinet? I am having a hard time trying to decide if I should invest in one, or use the equipment I have.
I would probably get one I think I just overloaded mine. I know what you mean I wire wheel brush my parts and then blast. The HF one I bought did a whole truck restore it still operates I just need to tinker with it now.
Has anybody used a vibratory tumbler for cleaning bolts and such? I bought a used HF one from a guy. He had it running when I picked it up. Found out why, it did not last long enough to clean the bolts I put in. Was wondering if they would do as good a job?
Yeah, he's talking about the same thing we are, the vibrating tumbler. I think these would work great on small parts. It can be a pain blasting them, and it's really a pain to wire wheel some of this stuff.
Like I said I used a HF one for my last project it worked great but it loosened up on me and I need to take 20 mins and disassemble it and tighten it back up with thread lock .Wire wheel brushing is not to bad as long as you don't wont your finger prints.
If you have access to a media blaster, I would go that route. I use a small metal basket (like ones found at Staples or Office Depot for desks) to hold a few nuts and bolts, then blast them in the basket. I have seen both the HF and Eastwood tumblers, but for the money you will spend on them, I would either just blast or replace the bolts.
I thought you guys were talking about the rotating tumblers, Sorry. I made a big tumbler out of an old dryer. Strapped a five gallon bucket with a threaded lid to one side of the dryer tub with a rachet strap. Was using play sand as a medium. It worked pretty good on some big brackets off my truck. Have some trouble getting the lid off the bucket though, the sand gets in the threads and locks it pretty good. I have a new bucket my dad got some pool chemicals in, going to try that when I get back to the truck project. Disconnected and removed the heater coils took the door off and install a toggle switch in place of safety switch. Can't load the bucket to heavy cause the small belt doesn't have enough power to turn drum. It is real noisy though. Did not try it on any bolts. Was just using it on U-bolt plates, shock towers and such.
Wow now that is enginuity at it best. If you could perfect that you need to post a diagram. Old dryers that the heater elements don't work or a dime a dozen. A 18 # tumbler is $200 or more.
