E-150 make good donor??
Old Jan 5, 2011 | 08:18 PM
RickyD's Avatar
RickyD
Picked up a 76 e-150 for the 300-6 I plan on using it in a 67 f-150, now I am wondering if the disc brake I-beams would be a bolt on. Maybe even the power steering. I am sure there is a conversion guru here that has done it. I have converted a 66 from newer trucks but am not familiar with econoline differences. Any advice is greatly appreciated.
Old Jan 5, 2011 | 09:46 PM
crazed87bronco's Avatar
crazed87bronco
I think there was a thread not to long ago about using a e series as a donor if I remember correctly it is more trouble then its worth you may be better off finding a f series truck instead but the motor is usable I think the trouble is in the disc brake setup and I beams someone correct me if I'm wrong on my information
Old Jan 7, 2011 | 11:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Econolines use a different P/S pump, P/S gearbox and related parts than F100/350's.
Econolines use different brake and suspension parts than F100/350's
Econolines use different motor mounts (steel supports/rubber insulators) than F100/350's.
What is needed to make this swap is a 1973/79 F100 2WD or 1975/79 F150 2WD.
Buy the whole truck, then you can get everything off it necessary, and sell what remains to recoup your money.
Note: 1973/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
Old Jan 9, 2011 | 03:40 PM
Ford_Six's Avatar
Ford_Six
The Econolines had the steering in front of the axle, the pre-79 2wd trucks had the steering behind the axle, so no it won't work.
The engine is usable but you will need a different oil pan as the vans used a rear sump while the trucks used a mid sump.
Old Jul 15, 2012 | 10:38 PM
BigMightySam5600's Avatar
BigMightySam5600
1989 Econoline 150 Parts??
If this thread exist elsewhere please post, newbie, this site has been a ton of help, so thank you.
My question is exactly what can i use from the 1989 E150 on my 1978 F150 4x4? I had thought the coils and leafs and shocks might be interchangeable.
Keith
fordf350camper
Jun 4, 2013 12:51 AM
Automator
Computer Chips & Tuners
Jan 17, 2010 05:54 AM
drstrangelove787
May 1, 2005 11:22 AM
pr
Jan 21, 2001 03:42 PM
