2003 4x4 Excursion Front Hubs - Help
Old Jan 5, 2011 | 01:35 PM
DadsBig03's Avatar
DadsBig03
I have a 2003 Excursion 4x4, 7.3L, and I just found my right front wheel so loose that I can move the hub assembly without the wheel on. This is for the wheel bearing/hub assembly, not the locking hub. I have gone through 11 pages of posts to find a reference for the repair with no luck, and the search function is not working for me. Does anybody have a post location (page #) I can look at, or just a list of the steps I need to do? Can these bearings be replaced/repacked, or does the whole assembly need to be replaced?
Hopefully, I won't lose my entire weekend. Thanks for your help.
Old Jan 5, 2011 | 08:34 PM
radmacks's Avatar
radmacks
Its my understanding that you have to replace the whole assembly. You will probably have to register to see the link the click on job diagram on the right hand side.
Wheel Bearing/Hub Assembly-Front | 2002 Ford Excursion 4WD 8 Cylinders F 7.3L Turbo Diesel | AutoZone.com
Old Jan 5, 2011 | 08:44 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
you need an entire new assembly. dont buy a cheap one. get the oem hubs or timken........
Old Jan 5, 2011 | 09:41 PM
wallz's Avatar
wallz
You can use this site for a few things as he works on an 02 7.3l truck.
http://www.guzzle7pt3.com/maint.php
Use the needle lube write up to see how he takes the hub off.
I have over a yr on cheapy eBay hubs with no issues yet.
Old Feb 10, 2011 | 07:52 PM
Richard2212's Avatar
Richard2212
Look here:
https://www.ford-trucks.com/forums/1...-bearings.html
Reed Russell
Nov 9, 2016 11:02 AM
prorad
Oct 7, 2014 03:03 PM
tfdcapt
32
Jan 19, 2013 01:55 PM
rburri
Oct 31, 2011 09:44 PM
02FX4Dude
1983 - 2012 Ranger & B-Series
May 9, 2006 12:14 PM
