Front bumper torque specs...
Old Jan 4, 2011 | 08:51 PM
Franko72's Avatar
Franko72
Molon Labe
Originally Posted by ja2488
Like I said, I got the toque spec but need the bold major diameter.
Looks like 11 mm or 1/2 inch to me
Old Jan 4, 2011 | 11:40 PM
ja2488's Avatar
ja2488
85 Foot Pounds.
Old Jan 5, 2011 | 05:16 AM
Franko72's Avatar
Franko72
Molon Labe
85 Foot Pounds.
Huh...I've tried 120 ft lbs last time, and the bumper still moved within a few miles.
Old Jan 5, 2011 | 01:06 PM
onelionhunter's Avatar
onelionhunter
Bar
Sounds like a 6 foot cheater bar and a 400 lb sumo wrestler is what ya need to get it tight.........
On a more seriosu note, i did use a 4 foot cheater bar to "snug" mine, it hasn't moved since.
Edit: One other thing I have used in the past has been a small piece of bicycle inner tube as a washer where the bumper meets truck for friction creation, holds like glue.
Old Jan 5, 2011 | 02:10 PM
Orezona's Avatar
Orezona
I used an impact gun on the highest setting.
Old Jan 5, 2011 | 02:16 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
I have had mine off several time due a plow mount and it has never moved and I just tighten the crap out of it. I would not use red loctite because if it moves again or you need to remove it for other work it will be a bear to break the bolts free. I suggest blue loctite and I would take everything off and clean it good, make sure there is no rust scale, dirt, etc.. between the pieces that would keep it form getting good metal to metal contact, out it back together and you should be good.
Good luck.
Old Jan 5, 2011 | 02:23 PM
clintbonnie's Avatar
clintbonnie
I would make sure you are not running out thread on the bolt.. Maybe just a washer would do the trick..
Old Jan 5, 2011 | 02:43 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Couple tack welds will hole it in place. That's what everyone around here does when getting the cow catchers put on.
Old Jan 5, 2011 | 03:42 PM
Brother Les's Avatar
Brother Les
I don't think it is the bumper...,
I think that the fenders are cocked a little
to much weight on one side.
Old Jan 5, 2011 | 03:43 PM
Franko72's Avatar
Franko72
Molon Labe
Thanks for all of the suggestions, I ended up putting on lock washers, and using red locktite. I torqued the bolts to 130 ft lbs.
It didn't move on the way home..... But we'll see what tomorrow brings.
I'm going to switch out this bumper (small dent) with my spare when I get back to Florida, so If todays fix doesn't do the trick , I'll break out the welder.....
Old Mar 15, 2021 | 04:01 PM
Ben Duffin's Avatar
Ben Duffin
i put a ranch hand on my truck and i torqued the bolts back to 75 foot pounds and havent had an issue
nut1605
Oct 6, 2017 08:58 AM
Binder Guy
3.8 & 4.2L V6
Jun 16, 2017 03:58 PM
Countryboy90
Jun 2, 2015 04:46 PM
Jarryd
Dec 30, 2013 04:18 AM
BigBass01
Jul 31, 2008 09:56 PM
