From my understanding (from what I read in the manual, it says nothing) of other valet systems I have used, it locks out the Nav unit from changing anything.
Or extracting personal information....
That's what I've read so far
Did you guys' get a valet key in addition to the other two admin keys with your trucks?
I only received two admin keys and would have to reprogram one to be limited (with myKey I would guess).
"Valet" is only mentioned in the manual once on page 148.
It is a setting in the Nav. You go to that particular screen and type in a 4 digit code. To unlock it, I think you push the 1 & 5 preset buttons. The explanation is better in the Synch supplement.
Then you probably don't have the valet mode. It was specifically for the Nav unit from what I can tell.
The MyKey thing is where you can put certain limits on what the truck will be allowed to do. If I ever need to "valet" my truck, I would use the second key in MyKey mode -- and lock the Nav too...
