Charging system problem
Old May 17, 2011 | 11:52 PM
maples01's Avatar
maples01
Does cruise control work, just to get an idea where to look, cause if it's at the booster or pedal, cruise will be dead, but could be at one of the wheels, rusty rotor maybe.
Old May 18, 2011 | 12:23 AM
Club Wagon's Avatar
Club Wagon
Haven't had to try & can't confirm it, but have heard that it's worth trying to reset ABS warning light the same way OBD2/Check Engine Light can be reset, that is try disconnecting the battery for ~10 minutes.
Continuing faults should relight these warning lights. There's an ABS tester that diagnoses faults in that system. A '91 has RABS, Rear ABS, which is a much simpler system than 4 Wheel ABS.
Old May 18, 2011 | 11:22 AM
masterclean5's Avatar
masterclean5
I don't have cruise control. I'll try disconnecting the battery for 10 minutes or so. Thanks guys. I'll let you know what happened.
ten.mile
May 16, 2020 04:34 PM
TowsonX
Jan 11, 2014 10:25 PM
slipbobber
Sep 20, 2011 05:35 PM
lakerats
Electrical Systems/Wiring
Dec 8, 2010 08:00 AM
lakerats
18
Oct 16, 2010 09:10 PM
