Tranny's staying warm
Old Jan 4, 2011 | 09:08 PM
izzybird's Avatar
izzybird
Bout 8 miles. No lift out at the house, maybe someday. It's on the list
If you get rid of the air intake heater and plug the hole, you can tap the plug for your boost gauge. Or you can buy them pre-tapped from a site sponsor such as Riffraff.
Old Jan 5, 2011 | 09:27 AM
hhowell1990's Avatar
hhowell1990
I think that's what I'll do to run tr line to my boost gauge so I don't have to cut the hose to my MAP sensor or drill and tap my intake. Anothe question, the pyrometer I'm looking at getting offers a band clamp with a bung on it do you Ruhr temp probe that way would leak at all?
Old Jan 5, 2011 | 10:09 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by big poppa
Even if you don't plan on modifing your truck seriously consider getting the trans, boost and pyro gauges, not only good for real time temps but for diagnosing problems, their worth their weight in gold IMO.
Very good advice Mike.
I will also suggest a fuel pressure gauge. It is as important as the other three. Now that I have one I wouldn't do without.
Old Jan 5, 2011 | 11:04 AM
izzybird's Avatar
izzybird
I put the pyro probe in the drivers side exhaust manifold. I was very leery of drilling a hole in my manifold but turned out to be no big deal. Once you have the first one under your belt, the sweaty palm syndrome goes away. Pyro probe location seems to be a "who you ask" type of deal, I stick with the manifold. Some instructions suggest putting grease on your drill bit to grab the shavings as you go. I now see there's no reason to do this. A drill bit is designed to pull shaving out anyway, not to mention your drilling upside down. Starting with a small bit and working your way up produces very small shavings that fall right out. A quick hit with a shop vac on the hole you just made sucks out any strays, and even if some were left behind they will pass the turbo with no ill effects. Some even stick a small telescoping magnet in there to grab any shaving left behind. There's nothing wrong with using the band clamp and bung setup that I know of, and will work fine for you if that's the route you take. You can also just drill and tap the uppipe instead of using the band clamp. Just keep it as close to the exhaust manifold as you can. Here's some pics one of install in manifold and one in uppipe.
Old Jan 5, 2011 | 02:34 PM
hhowell1990
@izzybird when u do te band clamp it's just going to be temporary until I get an aftermarket exhaust I just wanted to make sure they're not prone to leaking of anything like that and thanks for all the help
Old Jan 5, 2011 | 02:38 PM
hhowell1990
That's on my list of mods too, I plan on after getting my gauges installed on doug the F 650 dash mod and using the spa e on there to mount an AIC, switches for aux. lights and fuel and air pressure gauges
jim dillard
Mar 2, 2018 09:30 PM
ves83
Aug 28, 2014 11:10 AM
Ford4Life7.3
Jan 22, 2012 04:44 PM
fordtruckman
2004 - 2008 F150
Feb 5, 2007 03:57 PM
Ducster1
Jun 17, 2004 09:19 AM
