temp guage
Old Jan 2, 2011 | 04:17 PM
1bigjoe's Avatar
1bigjoe
temp guage
i covered the rad with cardboard to much and it got to hot while driving
the engine light came on and the needle climbed to the hot side, so i puled over and removed the cardboard, ---ok, so now two days later the needle still is on the hot side burried and the engine light stays on
what to do?
Old Jan 2, 2011 | 06:13 PM
rodneywar's Avatar
rodneywar
possibilly the gauge sender went bad
Old Jan 2, 2011 | 06:56 PM
1bigjoe's Avatar
1bigjoe
where is that.
Old Jan 2, 2011 | 07:03 PM
rodneywar's Avatar
rodneywar
here it is thank dave sponaugle for it
Old Jan 2, 2011 | 07:14 PM
1bigjoe's Avatar
1bigjoe
thanks to the both of you,i was looking for a picture. that looks like it is on the drivers side-in front,
Old Jan 2, 2011 | 07:33 PM
farmert's Avatar
farmert
The switch for the temp light is bad. If the temp gets high enough to activate the light it will override the sender for the gauge and peg the needle.
Old Jan 2, 2011 | 09:53 PM
wreckinball's Avatar
wreckinball
yep kind of like the check engine light. Once on it needs to be re done. That is why you simply do away with it for a mechanical gauge! hehe
Old Jan 3, 2011 | 08:24 AM
1bigjoe's Avatar
1bigjoe
so i can drive with no worries about it till i either replace it or disconnect it, or can it be reset?
Old Jan 3, 2011 | 10:00 AM
farmert's Avatar
farmert
Unplug the wire on the temp light sensor in the pic above, and the temp gauge should operate correctly if I'm not mistaken.
Old Jan 3, 2011 | 11:14 AM
1bigjoe's Avatar
1bigjoe
THANKS GUY'S I UNPLUGED THEM BOTH AND PRESTO-CHANGEO, BACK TO NORMAL. NOW TO TAKE IT FOR A DRIVE TO SEE HOW IT ACTS----THANK YOU ALL
cpettymore7777
Sep 19, 2010 09:08 PM
pidaster
Oct 12, 2009 03:08 PM
CaptGuz
May 15, 2007 05:40 PM
Spooky
Dec 2, 2004 01:44 AM
4x4_EB_Explorer
Jun 11, 2002 03:51 PM
