anyone know what tranny a automatic 2wd eb explorer has? im thinking about buying a 98 with tranny problems and a trashed interior.. and several other problems, but runs ok.. what mpg these get around town?
anyone know what a used good trans or rebuild goes for on these?
Since Ford decided not to allow band adjustment on most of their transmissions you have very few options. You can check transmission pressures but you are probably looking at rebuild or replace.
I would not be surprized to find that almost all of the 4R70s from 93 and up to 98 or newer would fit. I'm pretty sure the bolt pattern is the same. You should take the plate that goes between the engine and trans and compare to be sure. There are also some differences in the wire harness so you will need to check the pin out and compare that too.
