spark plugs
Old Jan 4, 2011 | 03:15 PM
pawpaw's Avatar
pawpaw
Originally Posted by CougarXR02
I've also had very good luck with the Autolite DPs.
PAWPAW, have you noticed a measurable difference in mileage? Or for that matter towing/ hauling power with the Iridium Enhanced versions?
I haven't been able to measure an increase in mpg with the fine wire iridium enhanced plugs.
Only noticeably faster starts, smoother idle in "N" & no random miss when on a hard lug when towing.
Old Jan 4, 2011 | 05:20 PM
CougarXR02's Avatar
CougarXR02
hmmm.....That's some food for thought. I certainly could use every advantage when towing.
Are they under $10 a plug??
Old Jan 6, 2011 | 06:46 AM
motorking's Avatar
motorking
Spark Plugs
Hey Ranger dudes,
I am the tech manager at Autolite. Interesting forum with some great and not so great information. I run Autolite XP104's in my 98 Ranger 4.0, it has 185k on the clock and runs great. The truck originally came with double platinum plugs, Ford (and many other automakers) now recommend using an iridium fine wire spark plug with a platinum pad on the side wire. That would be our XP spark plug. They retail for around 5.99-6.99 each. If you really want to know all about spark plugs, heat range, metallurgy and DIS ignitions, go to autolite.com and watch the autolite challenge videos. And yea, that ugly mug spouting off is me.
Peace
Old Jan 6, 2011 | 07:04 AM
powersmoked's Avatar
powersmoked
Motorking. I am running Autolite DP's in my 4 banger. Would the fine wires be better for me?
Old Jan 6, 2011 | 07:26 AM
creeker00's Avatar
creeker00
I just replaced all my Autolite DP's with OEM Motorcraft... so far I am pleased with the Motorcraft plugs.
Old Jan 6, 2011 | 07:32 AM
powersmoked
Creeker. I am pretty sure autolite and Motorcraft plugs are both made by Honeywell. Are the OEM. DP's and if not why would you do it
Old Jan 6, 2011 | 07:46 AM
creeker00's Avatar
creeker00
In my case the previous owner had installed the autolite dp's and the truck was giving him issues with misfires, bogging, etc... I removed the autolite dp's and tried the motorcraft plugs and the problem was resolved...
Old Jan 6, 2011 | 08:42 AM
powersmoked
Creeker...I realize you do not have enough posts to create a signature...so I dont know what engine you have........but if you have the 4.0.......I don't think MC makes the exact oem plug for the truck..........what was the actual part # of the plug you put in? was it a single platinum? etc...details details.......
* maybe the autolites were not gap properly? how long had they been in there......a lot of sellers lie about the maintenance?..........the only horror stories in these fords about plugs that I know of come from Bosch
also if the PO put to many fuel additives in the truck those can trash plugs, seafoam is know to do that.....
Old Jan 6, 2011 | 08:55 AM
creeker00's Avatar
creeker00
powersmoked - its a 4.0L OHV. I replaced the dp's with the Motorcraft OE Finewire Single Platinums, part no. SP486, I believe. He had just replaced the plugs and wires... he provided receipts when I got it off him. Not sure the plugs were the definite cause of the misfire, but that is what appears to have resolved it in my case.
Old Jan 6, 2011 | 10:46 AM
KhanTyranitar's Avatar
KhanTyranitar
Just because he just did it, doesn't mean it was done right. He may not have used the right plugs, one could have had a cracked insulator, a boot was not installed properly, etc. All your story states is that you do better work that the previous installer. The Autolite and Motorcraft plugs are 100% identical.
Old Jan 6, 2011 | 10:52 AM
pawpaw's Avatar
pawpaw
Originally Posted by motorking
Hey Ranger dudes,
Peace
Nicely "done show & tell" Jay, you did Good!!!!. Thanks for posting.
I watched all six video modules, After I figured out where they were located, (at the bottom of the "learn more" tag), then a way to get past the Region/Langage page, that wouldn't work to foward me & open the video module page for viewing.
Maybe you could have someone look into that Region/Language page to see whats up with it not fowarding after a region/language is chosen.
Anyway, I found the english video page here.
Autolite Spark Plugs - Choose your region | Autolite®
Think I'll start a spark plug tutorial thread & post a link to these videos & ask that the thread be considered for a "stickey" in this forums Tech Info thread.
Old Jan 6, 2011 | 10:58 AM
creeker00's Avatar
creeker00
I wasn't suggesting that the autolite dp's are bad or the motorcraft plugs are better or whatever... just simply stated, I replaced the dp's that were in mine with the motorcraft plugs and I am pleased with them.
claycomotrucks1991
6.2L V8
Feb 14, 2023 04:11 AM
z31freakify
Jun 28, 2016 08:24 PM
Nathan Cox
Apr 28, 2016 09:12 PM
illenema
Aerostar
Feb 1, 2010 01:46 AM
