Aerostar Ford Aerostar
New spark plugs
Old Jan 30, 2010 | 01:33 PM
illenema's Avatar
illenema
New spark plugs
Changing plugs on the 95. One in there are AGSF32PM. These are suppressorplugs not availe. Whats the proper replacement.
Are these original plugs?
Old Jan 30, 2010 | 02:17 PM
99f350sd's Avatar
99f350sd
What engine? 4.0l DP plugs Double platinum
Old Jan 30, 2010 | 02:39 PM
illenema's Avatar
illenema
3.0 engine
Old Jan 30, 2010 | 05:41 PM
99f350sd's Avatar
99f350sd
Out of my area.. Use motorcraft or autolites and you'll be fine. Single platinum.
Old Jan 31, 2010 | 01:29 AM
96_4wdr's Avatar
96_4wdr
does the 95 Aero 3L have a distributor or coil pack EDIS ignition?
if EDIS, use double platinum Autolites or MC
Old Jan 31, 2010 | 06:19 PM
Aeroman59's Avatar
Aeroman59
Thumbs up Motorcraft plugs
Yes, if you have the coil pack distributerless ignition, get double platinum Motorcraft or Autolite plugs. MC number AGSF32FM. Also the Ford plug wires are best for this vehicle. Probably 90% of misfires will be traced to bad/worn plugs or leaking wires.
Those plugs are looking like originals how many miles? Careful getting them out, spray some wd40 into the plug wells & let it soak for an hour or 2 before getting too ambitious!
Old Feb 1, 2010 | 01:46 AM
KhanTyranitar's Avatar
KhanTyranitar
Actually the best wires are Magnecores, but they are quite expensive. Just depends on your budget.
claycomotrucks1991
6.2L V8
Feb 14, 2023 04:11 AM
dobenator
Dec 6, 2016 12:06 PM
z31freakify
Jun 28, 2016 08:24 PM
Nathan Cox
Apr 28, 2016 09:12 PM
