UVC Wiring Firing Sequence
Old Jan 1, 2011 | 10:49 AM
Tater50's Avatar
Tater50
Can someone give me a little explanation on how the firing function works.
Seems like by the pics depict 4 sets of wires going UVC. These attach to GP's & Injectors?
Thanks Tater
Old Jan 1, 2011 | 05:39 PM
bobbyt89's Avatar
bobbyt89
pull the covers and you will see. i dont know if its possible to mess this up clip ends go to injectors and female plug types go to glow plugs and there only long enuf to go to there needed spot
Old Jan 1, 2011 | 06:23 PM
tjbeggs's Avatar
tjbeggs
Thanks Tater
4 plugs total into 2 valve covers. each connector feeds 2 glow plugs and 2 injectors. It splits under the valve cover
Old Jan 1, 2011 | 07:44 PM
Tater50's Avatar
Tater50
Logic
Thanks
My logic figured that, but wanted to have someone w/firsthand experience, since I got no manuals.
In the pic of the harness that I have; I see 2 plugs w/circlips that have 2 wires extending from them & 2 FM round plugs with 1 wire; is my logic correct in thinking that the circlips go to the injectors; maybe one to open, one to close injector???
Got a pic or can you describe what the layout of the 4 pins are? Outer pins/inner pins??? Trying to figure what the burned pin that I have found goes to; injector or GP. Both burned pins from different harnesses are the outer pins.
Tater50
Old Jan 1, 2011 | 07:56 PM
YoungFordAddict66's Avatar
YoungFordAddict66
for each plug -in there are 5 pins, 2 outer pins are the gp's, next two inner pins are for the injectors and the middle is common ground.
Old Jan 1, 2011 | 08:28 PM
Tater50's Avatar
Tater50
OK
I did a search for Pics & could not find any under the Tech Files; I hate to ask so many questions, but I cannot find any pics?
Thanks for the input: found some more info!!
Tater50
Old Jan 1, 2011 | 10:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Glow plugs ground through the block, one wire to each.
The solenoid on the injectors is not grounded to the injector, so two wires each.
Two glow plugs and two injectors per valve cover connector.
G - I - C - I - G
G = glow plug
I = injector
C = common ground
Old Jan 2, 2011 | 02:27 AM
richdawg's Avatar
richdawg
Maybe the fallowing links will help some.
97-15A 7.3L DI Turbo
