Leaf springs
Old Dec 31, 2010 | 01:14 PM
Taumac's Avatar
Taumac
Leaf springs
I got a 2000 Ranger 4 door and the leaf springs bushings are shot. I cant seem to find them anywhere except Ford. Does anybody know where to find them? I also have that rear sag in rear which I dont like the look of it. Can I use some 4x4 leaf springs from the same year? Will they fit and will they lift rear the 2 or 3 inches or is it better to use lift blocks cause I think being that I cant find those damn bushings I can get some used springs plus the the 4x4 it fix bushings nand lift it one shot. Let me know if you guys think it would work out?
Old Dec 31, 2010 | 02:00 PM
reddog99's Avatar
reddog99
Try this for bushings:
energysuspension.com | Welcome
I don't know for certain that the 4x4 springs will fit, but I believe they will. Most of the extra 4x4 height comes from a block between the axle & spring.
Old Dec 31, 2010 | 02:40 PM
powersmoked's Avatar
powersmoked
I cant answer the leafspring question, however rockauto sell the bushing and bolt for about $20 they also sell the shackle kit that includes those for $20 the kit is made by Dorman.I used it on my truck. are you sure your shackles and hangers are not rusted out.......strange that the busing is worn but the shackle is fine.........I don tknow your location. that makes a big difference
*I just looked up your location= FLA. that would explain the dried out bushings and non rusted shackles
Old Jan 1, 2011 | 01:27 AM
Taumac's Avatar
Taumac
Thanks, It a FL truck basically rear bushions it the leaf spring are all dried out and cracking so was going to replace them. Ill look into that place for everything. I went to autozone and they didnt even list them so guy went into book for energy suspension and they wernt listed but ill check thru website. Ford want $8 per each side of each spring and thats without pin so $32 just for rear part. I forgot offhand for front with shackle but it wasnt cheap.
Old Jan 1, 2011 | 05:12 AM
powersmoked
it sounds like the ford product for once is cheaper.......go with the ford ones maybe you can reuse the bolts........
michigan66's Avatar
michigan66
LMC Truck carries spring bushings. You can check their web site for fitment and price.
Old Jan 1, 2011 | 07:27 AM
smalltrucker's Avatar
smalltrucker
The Ford shop manual lists five different rear springs for the 2000, makes no difference if 4x4 or not. number three highest rating and letter "N" is lowest. Info on you door tag.
Dave
Old Jan 2, 2011 | 12:25 PM
Diesel_Brad's Avatar
Diesel_Brad
Check here Leaf Springs and Air Ride Suspension specialists offering Timbren kits, helper springs, and Air Lift kits.
They are excellent
Old Jan 3, 2011 | 09:23 PM
Taumac's Avatar
Taumac
Thanks guys I found a nice set at Energy Suspenion think like $32 -40 but I still gonna check into some springs possibly. I found this link if anybody interested http://store.summitracing.com/partde...5&autoview=sku
Old Feb 8, 2011 | 10:55 PM
Taumac's Avatar
Taumac
Well I just got some but have a question. Mine on the truck are 2/1 with code F87A and the ones I picked where out of a 2003 supercab (unknown engine/drivetrain) 3/1 with code 3L54. You said something about spring codes I know but do you have a link or info on how the read these nums? You said "3" highest and "N" lowest.
Old Feb 9, 2011 | 04:12 AM
Diesel_Brad
The spring codes are on the door jamb sticker
Old Feb 9, 2011 | 08:38 PM
Taumac's Avatar
Taumac
I can read mine off my truck but bought springs from savage yard and forgot all about reading the door jam. I just saw a set off springs on a 2002+ rangers with 3/1 vs my 2/1. For a 8 yr old truck springs and bushing look almost brand new.
Old Feb 10, 2011 | 05:05 PM
smalltrucker
[quote=Taumac;9942589]Mine on the truck are 2/1 with code F87A and the ones I picked up were 3/1 with code 3L54. quote]
Those number F87A and 3L54 along with the 2/1 and 3/1 mean nothing to me. The codes for the front springs are
A. C, D, E, G, H, J, 2, 3
Torsion Bars:
B, F. 1
Rear Springs:
3, 7, C, K, N
On the door data info, the first number/letter is the front while the last is the rear. I found some other data that lists the spring rating by the dimensions but even the springs with the same dimensions can have different load ratings, depending on how they are tempered.
Dave
ryanf77
Nov 21, 2013 05:37 PM
Hyperactive460
Apr 17, 2013 10:28 PM
TheWhiteBeast
19
Oct 7, 2011 12:02 PM
jjuchems
Oct 18, 2010 10:12 AM
Moore558
Feb 18, 2008 02:47 AM
