'84 E250 is missing the switch to operate the W/Ws. It seems there was a slider type switch to act as a timing device for the delay. I have searched the wrecking yards here and cannot find anything like what I need. Does anyone have any info on one? Either a new switch or a wiring diag. so I can patch another switch in.
HAPPY NEW YEAR to all FTE members!
I have never seen a van in those years, but I know the trucks in those years had the timing function built into the single round ****. Turn it to the right and you have the normal 1st click low speed, 2nd click high speed. Turn it back to the left to off, and then keep turning it, and you will find a large area where they will work on low and you can vary the timing.
If you find one of these in the junkyard, take the switch out, and follow the wiring from the switch and you should come to the delay box. It's sold as a assembly, so I would take switch and the timing box out together.
