Arizona Chapter Join Chapter, Leader:
e40d broke today
Old Jan 4, 2011 | 07:44 PM
helifixer's Avatar
helifixer
remove cross member, let transmission down with a jack placed out of the way of where your transmission jack will be (don't go so low that stuff in the engine compartment starts breaking) long bar and roll body seam out of the way, 4 foot extension and a universal socket, take top bolts out.
Old Jan 4, 2011 | 07:47 PM
helifixer's Avatar
helifixer
p.s. is your obs a powerstroke of a gas engine? that will matter on a transmission, powerstroke is an American bolt pattern and the gassers are metric
Old Jan 4, 2011 | 07:50 PM
96f350az's Avatar
96f350az
thats what ive been reading. thanks for the reply.
should be fun. hahaha
Old Jan 4, 2011 | 07:51 PM
96f350az's Avatar
96f350az
and 460 gasser.
thanks for that tip.!
Old Jan 4, 2011 | 07:53 PM
Bill W's Avatar
Bill W
Originally Posted by 96f350az
lol. funny where this went.
lil update. laid under the truck today.
pulled rear driveshaft dont have a 12pt 8mm for the front?
starter
draind fluid nice brown with alot of glitter...yay....
dropped exhaust as much as i could. idk how to get up to the top bell housing bolts.
stared at it..
anyone have a tip for getting to the top bolts bellhousing/block?
a couple of long extention's with a swivel will get you there without any trouble. i have a few long 1/2 inch if you need. not sure about the 12 point 8mm though
Gary, the trans will be going behind a 289 with a mild cam... nothin special. maybe 250 hp if i am lucky... so, i am up for ideas/advice from someone who knows.
thanks.
Old Jan 4, 2011 | 08:21 PM
96f350az's Avatar
96f350az
thanks Bill ill be down by you tom since thats where the trucks at . if i hit a snag ill shoot you a call. thanks again.
this is what the oil looked like. i think i have more problems then i thought
and the filter just fell with the pan. is that normal? haha
the o-ring is still up there and ill be sure to pull it off before it gets replaced.
Old Jan 4, 2011 | 08:22 PM
96f350az's Avatar
96f350az
see all the sparkles its glitter!!!!
and the chunks...
plus its seperating like water???
Old Jan 4, 2011 | 08:44 PM
GWR928's Avatar
GWR928
5th Gear
Bart, I forget sometimes that they make spark plugs! Similar internals though. Bill, I'm guessin your tranny is case fill? Dip stick goes into the case and not the pan? 96f350az, it looks like aluminum? if so more than likely planet failure.
Old Jan 4, 2011 | 08:54 PM
Bill W's Avatar
Bill W
it's from a 66 mustang... i have 1 complete and one unassembled, bead blasted, all parts are clean and ready to put together. Case fill? Yes, the tub goes to the case but its right above the pan. so, not sure exactly which is which.
Old Jan 5, 2011 | 11:41 AM
GWR928's Avatar
GWR928
5th Gear
Bill,
you can contact me @ (928) 713-0030. I am headed to Colorado for a couple weeks on the 17th.
Gary
Old Jan 5, 2011 | 11:51 AM
96f350az's Avatar
96f350az
yah its the forward planetary....is what my tranny guy assumes.
gonna hop under it in an hour or so... and freeeek out. should be fun dropping it alone. haha
with 1 floor jack....
Old Jan 5, 2011 | 11:58 AM
Bill W's Avatar
Bill W
Call me if you want a supervisor! errr.... hand with it.
Old Jan 5, 2011 | 12:05 PM
  #28
DRRXR's Avatar
DRRXR
I read where you mentioned that the filter dropped with the pan. You think that you may have dropped it and then starved the pump and cooked the planitary?
Here is where you can do the temp install.
And Gary aka GWR928 thanks for the tip on the TransGo
Old Jan 5, 2011 | 01:14 PM
  #29
96f350az's Avatar
96f350az
^^ thats what im thinking. it wont stay up there so it makes damn good since.. now im kinda nervous about this design. thanks for the diagram as well
bill, im probly gonna take you up on that man. leme head down there and ill shoot you a call if i get ready to ripp it out with a loader.... thanks again.
Old Jan 5, 2011 | 03:44 PM
  #30
DRRXR's Avatar
DRRXR
From your pics looked like the o-ring was still on filter, If you are not the org owner you think someone else could have over looked the old one stuck up in there? Its not uncommon to over look the o-ring stuck in there and is its left then the filter will fall.
Best of luck and keep us posted.
