door mirror placement?
Old Mar 5, 2003 | 11:59 AM
J Selman's Avatar
J Selman
I took the large mirrors off my 70 and I'm installing a set of the small factory stye mirrors! I made a template from an old set of doors I have, But the placement of the pass. side is 1-2" ahead of that of the drivers side. Is that right?I just want to make sure before I drill the holes!
Thanks,Johnny
Old Mar 5, 2003 | 03:26 PM
fast70's Avatar
fast70
Arrow door mirror placement?
hey dose this pic help you any it is out of the original 1970 option book from the dealer i cant incert it in here if you give me your email i can send you the pic i got
Old Mar 5, 2003 | 05:43 PM
J Selman's Avatar
J Selman
My email is selman@beachlink.com. Does the pic show both sides? All I really need to know is if the pass side is 1-2" closer to the front than the drivers.
Thanks,Johnny
Old Mar 7, 2003 | 07:23 PM
J Selman's Avatar
J Selman
I have searched thru a ....lot of pics of these trucks trying to find the answer with no luck.Some trucks both sides appear to be the same while others look as if they are different . The angels of the pics aren't usual good on both side to make an accurate decision.
If anyone has small factory mirrors on their truck and will measure the distance from the front of the door to the mirror on each side i would greatly apreciate it.
Thanks,Johnny
Old Mar 8, 2003 | 08:33 AM
jor's Avatar
jor
Johnny,
Just some unsolicited advice. Don't ever post your real email address on the forums or you will be inundated by spam in short order. I speak from experience. Just use the private messaging feature and live happily ever after.
jor
Old Dec 23, 2003 | 03:21 PM
herdfan75's Avatar
herdfan75
Did anyone ever come up with a measurement on the placement of the small door mirrors? I need to know for my '69 Ranger. Thanks.
Old Dec 23, 2003 | 03:44 PM
NM5K's Avatar
NM5K
Myself, I prefer them at the same distance from the front. I notice that most mirrors seem to be mounted just at the pillar for the wing vent/ side glass. This places the mirror just barely behind the pillar and gives good vision. Usually mounted about an inch or so below the window line. I put some 80's ford mirrors on mine a while back. I mounted mine in this position and it worked out fine.
Do a double check on the vision before you nail them down..
MK
Old Dec 27, 2003 | 07:03 PM
19felix69's Avatar
19felix69
I have another little tip...make sure you can still open the wing vent. I painted a couple of the van/truck mirrors from wally world and put them on...today i was needing some ventilation and the window clears by about 1/8 of an inch.
