trans question
Old Dec 30, 2010 | 10:58 AM
noblow93's Avatar
noblow93
trans question
I have a 93 F250 na 7.3 with a E4OD trans that is bad. will a E4OD out of a 97 powerstroke bolt up and work in my 93? tia
Old Dec 30, 2010 | 01:26 PM
galute's Avatar
galute
From what I understand the 97 trans is the most desireable. It has already had some of the upgrades done to it from the factory. It will work but I'm not sure if there is anything you will have to do to make it work as I have never tried it myself.
Old Dec 30, 2010 | 01:30 PM
rodneywar's Avatar
rodneywar
ok the tc need to be for a 90 truck cause it has 4 studs vs psd has 6 studs also the solenoid bodys need to be swapped out cause the psd solenoids will fry the tcu in our trucks. so you will need to buy a tc and solenoid body for a 90 truck then you can go
93'Bronco
1978 - 1996 Big Bronco
35
Jan 27, 2014 07:02 AM
Shovelhead 93
Jul 10, 2005 10:19 AM
Goble18
May 24, 2004 11:19 PM
BigBronco93
Dec 1, 2001 11:33 AM
car 36
Jul 19, 1999 04:36 PM
