Fuel pump replacement
Old Dec 29, 2010 | 09:01 PM
sdc150's Avatar
sdc150
Hi Fellow Ford Fans.
New project- 1977 F150, 460.
Truck has an aftermarket fuel tank with pump connected to frame rail on driver-side. Also has a pump mounted on motor in original location, but is not currently connected to fuel line/carb. Have cranked motor after being dormant for some time, but now time to turn it over.
Your thoughts- should I try to re-connect fuel line to original pump and rear tank...or connect the aftermarket set-up?
Thanks in advance!
njjr
Oct 9, 2015 02:54 PM
paker
1997 - 2003 F150
Mar 24, 2015 11:10 PM
rdemilt
Mar 18, 2015 03:22 PM
bshackelford711
24
Oct 3, 2013 10:14 PM
4beatg8
Jun 17, 2008 11:13 PM
