concrete stains?
Old Dec 29, 2010 | 08:34 PM
oldfordisbetter's Avatar
oldfordisbetter
concrete stains?
whats best product/procedure to remove oil stains from concrete driveways.. that are a few years old...
Old Dec 29, 2010 | 09:45 PM
BullyDogJason's Avatar
BullyDogJason
Former Vendor
muratic acid maybe
Old Dec 29, 2010 | 09:50 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Muriatic acid will eat the concrete away. What you want to try to do is "draw" the stain out of the concrete.
What kind of a stain are you trying to remove?
Old Dec 30, 2010 | 07:11 PM
oldfordisbetter
as i said. OLD OIL STAINS
Old Dec 30, 2010 | 07:57 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Give a power washer a try. Only problem I've found with that method is, it makes the concrete look so good where you're cleaning it, that you feel obligated to all the rest of the concrete.
Old Dec 30, 2010 | 08:48 PM
kermmydog's Avatar
kermmydog
What I learned & used from years ago is plain ole TIDE laundry soap Granulated. Wet the concrete sprinkle on some Tide & get a stiff broom & work it real good then wash off. It may take a few times.
Craig
Old Dec 30, 2010 | 10:04 PM
hanklin's Avatar
hanklin
what kind of oil? lol
Old Dec 30, 2010 | 10:08 PM
Kapusta's Avatar
Kapusta
I just use some cement powder and rub it on the oil stain.
Old Dec 31, 2010 | 01:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Radiator Specialty Company (Yes, the folks who make Gunk engine cleaner)
Have a product that works great, it's called SWAB.
Get the powder, not the liquid.
Old Dec 31, 2010 | 06:41 AM
oldfordisbetter
i did pressure wash it... no luck. tried tide, bleach, im just about to use that garage floor expoxy with the chips in it from home depo...
Old Dec 31, 2010 | 07:38 AM
sowder's Avatar
sowder
I have had good luck with a cleaner called "Oil eater" made by Kafko International Ltd.
I get it from my oil supplier. Google it to find dealers, it is great on smooth shop floors, don't know about rough driveways.
Old Dec 31, 2010 | 08:45 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Are you going to use the garage floor epoxy and chips on your driveway, or inside the garage??
(No mention of garage until now. . . . )
IF you're trying to remove stains from the garage floor, get some "Clean-Sweep" and spread that on the old oil stains and let it sit for a day, or so.
Repeat a couple of times. "Clean-Sweep" will HELP draw the oil out.
Also CRC Brakleen will cut/disolve oil, too.
Old Dec 31, 2010 | 09:13 AM
macgiobuin's Avatar
macgiobuin
I went to the Dollar Tree and bought 2 bottles of the off-brand GREEN degreaser and 2 bags of cheap clay kitty litter. Sprayed on liberally and then put litter on top. Then took a stiff broom and worked it in.....added more degreaser and topped with cat litter. Let it sit for a few hours, then repeated the procedure. Worked like a charm...most of my stain was transmission fluid, though.
Old Dec 31, 2010 | 12:51 PM
Ford_Six's Avatar
Ford_Six
Powdered laundry detergent with bleach works great. Don't wet the concrete, just sprinkle it on scuff it in with your shoe and let it set. Next time it rains the stain will be gone.
Old Dec 31, 2010 | 03:23 PM
im2tall33's Avatar
im2tall33
a weed burner will burn the stains out and it wont leave a burn mark..
