i have oil going into the radiator. i have flushed the radiator and it still seems to be getting in there i assume that i have a bad oil cooler i have taken an oil sample and sent it in and there is traces of coolant in the engine oil. i am worried about cavitation and i have done a compression test and all cylinders are in the 400s and i don't get any bubbles in the radiator. any ideas thanks in advance!!!
Ford
Front seal/gasket number E3TZ-6A636-G $3.58
Rear seal/gasket number E3TZ-6A636-H $4.04
innner O rings 1C3Z-6C610-BA $3.58 each
Outer O rings 1C3Z-6K649-BA $9.19 each
IH
DRAWER GASKET 1804378C2 $4.31 US
DRAWER GASKET 1804377C4 $4.31 US
1217175 RING 1807563C1 $10.07 US
1217175 RING 1804414C1 $6.62 US
International (much cheaper). International parts #s are (each is a bag of 2 rings);
-thicker ring 1804414C1
-thinner ring 1807563C1
If you want the oil cooler R&R info email me....... click on my name.
he doesn't have hydro-locking witch is a symptom of cavitation oreo had hydro-locking iirc and if it was a hg he wont be getting all cylinders in the 400s granted the oring in the hg can fail mine did and leaked to the outside of the block
