Replacing radiator tomorrow
Old Jul 16, 2008 | 03:26 PM
BlackNGoldRules's Avatar
BlackNGoldRules
I have a brand new radiator that I'm going to replace my leaky radiator with tomorrow. The radiator came with 3 pairs of rubber o-rings or gaskets. Each pair a little bigger and thicker than the other. My question is, where do these rings go? Do they go underneath the hoses where they are connected to the fittings? I have 6 rings but only 4 fittings on the radiator. Two for the radiator hoses and the two for the oil and transmission coolant hoses. I'd like to know exactly what they are for and where they go, if I need them at all, before I get started on this. Thanks for any info you guys can give me on this.
Old Jul 16, 2008 | 10:39 PM
BlackNGoldRules
Anybody know what these are for? I'm hoping someone can tell me before I start on this tomorrow. Thanks.
Old Jul 17, 2008 | 12:23 AM
Pablo-UA's Avatar
Pablo-UA
Ouh, 2 pairs small rings for tranny cooling lines, but what the 3d pair I dont really know... I have aero with 5 st tranny and got a radiator with small pack of rings. Were not used
Old Jul 17, 2008 | 12:48 AM
BlackNGoldRules
That's actually what I was thinking they were for but it threw me off since I got 3 pairs of rings with it. I guess they just threw a couple of extras in there. Thanks for your help.
Old Jul 17, 2008 | 08:06 AM
tomw's Avatar
tomw
Ford used multiple ways to connect the trans cooler lines. Some had screw-in fittings, some had fixed 'receivers' with push in or snap in connections. Who knows, just match the ones to your current fittings.
The snap together or push together ones should NOT be unscrewed from the radiator to disconnect the lines, as it will ruin the O-ring inside the snap connector. You have to use the 'special tool' to disconnect the line fittings from the connector push fittings, and then you can unscrew the fittings that are still on the radiator that the push-in fittings push into. Wow is that a bad sentence.
Guess how I found out? When the Dexron was leaking onto the floor...
tom
Old Jul 17, 2008 | 10:13 AM
Pablo-UA's Avatar
Pablo-UA
Unification and globalisation....
Old Jul 17, 2008 | 06:19 PM
BlackNGoldRules
tom
Unfortunately, I didn't have time to get to it today. But, I was reading the Haynes Manual and it says to hold the fitting, on the transmission line, with a wrench while loosening the fitting on the radiator with another wrench. I think that's what it said, but I'll have to go back and read it again. It shows a picture, but the picture is in b&w and not very clear. I'll just go by what it says, and hopefully it won't take a lot of elbow grease to get them off!
Old Jul 18, 2008 | 01:03 AM
BlackNGoldRules
Actually, after reading the manual again, I'm a little confused on what gets loosened concerning the removal of the tranny cooler lines. Anybody out there with a 2000 Ford Ranger that can help me out on that? I just want to make sure I don't end up tightening something instead by accident and make it impossible to get off. Thanks.
Old Jul 18, 2008 | 06:16 AM
Pablo-UA's Avatar
Pablo-UA
Nothing unusuall, i'm not actually sure 17 ore 16 mm wrench, loosen carefully 2 nuts, pull lines and then replace small o-rings, install new radiator, carefully screw nuts, fill cooling system, add 2-2.5q of ATF (all what was in radiator) and run engine. Check all againe...
Old Jul 18, 2008 | 07:45 AM
Fordsflylow's Avatar
Fordsflylow
Make sure the trans fittings on the new rad are going to match the fittings on the lines. I replaced my rad a few months back due to the seal between the aluminum and plastic/vinyl failing. I don't remember which brand the first one I had was but I took it back and got a Modine from napa and still had to rig up the fittings. Was a real pita and doesn't look the greatest (i.e. clamps and hoses) but it works.
Old Jul 18, 2008 | 07:57 AM
tomw's Avatar
tomw
If there are whitish plastic thingies sticking out of the connections near the radiator, you have a snap together type connector. You are supposed to disconnect there, rather than unscrewing the fittings from the radiator. That is what I was trying to describe. If you unscrew the fittings, you will cause the internal O-rings to fail.
IF you have snap fittings...
tom
Old Jul 18, 2008 | 02:58 PM
BlackNGoldRules
tom
I don't have the snap fittings. It's supposed to screw out somewhere. Maybe it would help if I actually knew what the end of the tranny cooler line looks like that connects to the radiator. Can I post a pic on here to show you guys what the connection looks like before I try taking it off? Then maybe someone can tell me which part screws off with the one wrench and which part I'm supposed to hold with the other wrench like the Haynes manual was talking about. Sorry to keep going on about this, I just don't want to strip something turning it the wrong way or turning something that I shouldn't be turning at all. If that makes any sense. Once I figure this out, the rest is pretty easy. Thanks.
Old Jul 18, 2008 | 03:17 PM
Pablo-UA's Avatar
Pablo-UA
worry about nothing... try to replace! you have spare o-rings... )
Old Jul 18, 2008 | 03:36 PM
Fordsflylow
You'll see the threads where the fitting screws on and it's a normal thread, righty tighty lefty loosy.
duckdaddy
Modular V8 (4.6L, 5.4L)
Aug 13, 2014 01:30 PM
Dtmaster2008
May 29, 2013 11:49 PM
Averill7
6.7L Power Stroke Diesel
Mar 11, 2012 05:02 PM
Dre82s
Mar 10, 2012 02:08 PM
Anafiel
1978 - 1996 Big Bronco
May 8, 2011 04:04 PM
