Removing 87-91 guage cluster...
Old Jan 1, 2011 | 03:37 PM
EPNCSU2006's Avatar
EPNCSU2006
The "EMISS" light was only used in '87 as best I can tell. Likely it was never there at all.
As for figuring out what goes where, just follow the printed circuit on the cluster. It will lead right to what it goes to. I'm not so sure that resistor is for the oil pressure gauge. The oil pressure circuits are on the top side of the connector attachment above the resistor. '87 or '88 was the last year for the variable resistance oil pressure sender, so there's a chance the cluster does not need any modification.
Old Jan 1, 2011 | 07:31 PM
Eddiec1564's Avatar
Eddiec1564
Yep thats the resistor to jump over. If you notice just above the resistor there is two copper pads, Those are solder points from the factory to bypass(jumper over) the resistor. Best thing to do is solder on the resistor legs, do not use TOO much heat as the plastic will melt. Sometimes solder will not stick to the resistor, just scratch the legs and solder should stick. Use only reison core solder, never acid core!
Old Jan 2, 2011 | 08:52 AM
EPNCSU2006's Avatar
EPNCSU2006
After doing some searching, that is not the resistor to jumper for the oil pressure gauge. The cluster pictured above is already setup for the variable resistance sender.
See photos near the bottom of the page here: Ford Oil Pressure Gauge Fix
You will see a second resistor above the resistor pictured here in this thread. The resistor on the top side of the printed circuit is for the oil pressure "gauge."
Old Jan 3, 2011 | 11:22 AM
nstueve's Avatar
nstueve
So something is wrong then... I put the variable pressure oil sender in with a 45* brass angle. If my guage is setup for "real oil pressure" why is it that I now have the red "engine" light on, and my guage reads low oil pressure???? It also doesn't move when i rev the engine... I already replaced the oil pump and screen and have been changing the oil regularly... The engine also looks nice and clean from the bottom side (crank, etc...) and from the top (under the valve cover).
Old Jan 3, 2011 | 01:49 PM
nstueve's Avatar
nstueve
I went back and re-read all the information i could. it seems that sometimes dealer installed early verision with the pressure switch put the resistor inline right outside the pressure switch under the hood. Also I might have put too much teflon tape on, so it's not grounded. I'm going to go and check both those things tonight.
Old Jan 3, 2011 | 01:56 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have a resistor jumpered across the bulbholder itself on my '87 cluster.
Have to assume it came that way from the factory, but maybe it's just for charging???
Old Jan 3, 2011 | 02:18 PM
nstueve's Avatar
nstueve
Well I confirmed the position of my oil guage
So if I needed a jumper it would be the upper left resistor like eric said. So my guage is golden! unfortunatly this means I have another problem somewhere else... I am going to check for another inline resistor on the sending wire when i get home and try grounding the switch out... I definatly don't get variable oil pressure so hopefully it's something simple like needing a ground... So here is the question... If my sender isn't grounded at the block would my guage read at all? because I have been getting a steady oil pressure... right where it shows in pic above. it does not move when I rev motor up though... Any other thoughts would be great guys!
Old Jan 3, 2011 | 02:38 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It grounds through the sender to the block. (at least mine does)
What is the engineering number on the sender unit that you have?
Old Jan 3, 2011 | 02:45 PM
nstueve's Avatar
nstueve
i'd have to get back to you on the sender number. All I know is that it is a Borg Warner sender... I used another NAPA part number to cross reference to it that someone else posted. Yeah i know it grounds to the block through the sender... If i have to much teflon tape on it and it isn't grounded would it run at all though??????? mine shows low OP... like in pic above...
Old Jan 3, 2011 | 03:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You could always disconnect the wire and ohm it out as you rev the engine.
An analog meter responds faster in a situation like this.
Old Jan 3, 2011 | 04:17 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The EMISS light is connected to an hour meter up inside the dash.
Called something like "Inferred Mileage Sensor" it sets off the light every 70kmi or so and is a reminder for you to service the A.I.R. pumps and their related plumbing and valves.
Old Jan 3, 2011 | 05:01 PM
EPNCSU2006's Avatar
EPNCSU2006
Yep. I've unplugged the module on my truck, moved that wire and bulb to the check engine light circuit and connected that wire to a pass-through into the engine compartment and the STO wire on the computer to make the check engine light work. Am I correct in thinking this was used only in '87?
It may still be grounded, but with a higher resistance. The higher resistance would cause the gauge to read lower.
The factory gauge on my truck doesn't move much, is slow to respond, and rides in a similar position to yours. I notice the biggest difference in gauge position between cold start and hot idle. Other than that it really doesn't follow engine speed like the mechanical gauge. Might be due to the teflon tape I used too, although it has never been low enough to turn on the red "engine" light.
Old Jan 3, 2011 | 05:16 PM
  #28
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Eric,
I'm not sure that it was ONLY in '87, but as a data point my 1987 definitely has it connected.
My gauge moves quite a bit and seems to reflect actual oil pressure at all times.
Old Mar 29, 2017 | 04:03 PM
  #29
Todd Goodwin's Avatar
Todd Goodwin
I know this is an old thread but quick question. Would bypassing the resistor also fix an issue with the fuel gauge? I have an oil gauge and fuel gauge not working. We have replaced the fuel sending unit already and supposedly it is getting signal to the cluster. The oil pressure is good just not registering. It does on one cluster but not the other so I suspect the oil issue is the resistor on that cluster but the fuel gauge stays full on one cluster and 1/8 on the other cluster.Any help would be greatly appreciated. I have another cluster that the fuel and temp gauges aren't working on it and don't know why.
Old May 21, 2017 | 06:28 PM
  #30
Brian Ski 44's Avatar
Brian Ski 44
No the resistor is just there for the oil gauge. It is to increase the resistance to the gauge so the gauge does not peg to the right.
pcman
Sep 20, 2017 03:07 PM
Brian Ski 44
19
May 31, 2017 06:37 PM
Building_Fords
Feb 22, 2017 09:30 AM
Cruiseomatic
WTB - Parts & other
Oct 29, 2016 07:13 PM
Kyle87
16
Mar 16, 2016 09:25 PM
