Axle Codes?
Old Dec 29, 2010 | 01:20 PM
sandmaniac's Avatar
sandmaniac
Axle Codes?
Just wanna find out what my rear axle code means, the tag on the door jamb is "C1"? I've looked and looked, I do know the letter indicated a "LS", but wondering what the number refers to. Thanks and Happy new year!
Old Dec 29, 2010 | 03:37 PM
BadDogPSD's Avatar
BadDogPSD
C1 = 3.73 limited slip F250/Excursion
Old Dec 29, 2010 | 04:43 PM
Waltdog's Avatar
Waltdog
of American machinists
From the Super Duty tech folder:
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
https://www.ford-trucks.com/forums/4...lder_____.html
Old Dec 29, 2010 | 07:47 PM
sandmaniac's Avatar
sandmaniac
Thanks Waltdog
I swear I looked all over for that, thanks alot. Put a bookmark on that baby! I recently replaced the diff cover and replaced with the 08 version, really sweet. Just wanna make sure that the tags matched the door sticker, and that I serviced with the correct lube.
Old Dec 29, 2010 | 10:07 PM
GEugeneS's Avatar
GEugeneS
This is what I had on a 99:
For a 1999 F-250 Super Duty Power Stroke, the codes on the rear differential tag are :
S409B
3L73 102 8C11
The break down of these codes:
S409B:
S = Sterling Differential
409 = Print Number (Model Number)
B = Revision Identifier (Change in Design)
3L73:
3L73 = 3.73 Ratio
L = Limited Slip
Absence of L = Open Differential.
A 3.73 geared limited slip axle would be marked as : 3L73.
An open differential would show 3(space)73.
102 denotes the ring gear size. 10.25 inches.
8C11 is the build date.
8 = year of manufacture. In this case it means 1998.
C = month of manufacture. A= January, L= December so C= March
11 = day of manufacture. So My differential was manufactured on March 11,
1998
Hope this helps as well.
Old Dec 7, 2022 | 11:06 PM
fishslab's Avatar
fishslab
4wd Low
2004 F350 DRW
Axle Type
I have a 2004 F350 DRW with a axle code F2. How do I tell if it's a Dana or Sterling?
Old Dec 8, 2022 | 03:24 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
DRW is going to be a Dana 80.
NJBronco94
Sep 20, 2010 12:09 PM
truckfella
Modular V10 (6.8l)
Aug 9, 2010 06:43 PM
supr_sly
May 4, 2009 02:15 AM
dkf
Modular V10 (6.8l)
Aug 14, 2008 06:17 AM
Nick Danger
Jan 27, 2007 08:54 PM
