Anyone Tried This?
Old Dec 29, 2010 | 10:04 AM
cowmilker08's Avatar
cowmilker08
Question Anyone Tried This?
http://www.dieselorings.com/docs/dipstikflange.pdf
Has anyone tried this? If so, how did it work?
Old Dec 29, 2010 | 04:31 PM
mongo12's Avatar
mongo12
that seems like a waste of time. .02 besides how can the dipstick orings go bad if it just sits there and only gets touched when u change the oil or check occasionally? maybe someone has had luck with that but to me it seems like a pain if your not rebuilding the engine.
Old Dec 29, 2010 | 04:46 PM
Ken_C's Avatar
Ken_C
there have been guys here who have had their dipstick tube flange leak. it is not fixable unless you remove the oil pan. (Until now apparently) the only way the pan comes off is pull the engine so if this is a fix and it works it will save alot of headaches.
Old Dec 29, 2010 | 06:17 PM
pjwoolw's Avatar
pjwoolw
Looks like a good kit Phil. I haven't had to change that but I might as well give it a try next oil change. Mine does seep a bit. I've seen a bunch of similar threads on how to change the o ring. Most using vise grips. The brush idea is a good one. I hadn't seen that on Bob's site before.
Old Dec 29, 2010 | 07:08 PM
Midwest Dually's Avatar
Midwest Dually
I havent had any bad luck with any of their other product line, so I would give it a shot!
Old Dec 29, 2010 | 07:54 PM
Desert Rancher's Avatar
Desert Rancher
I did it.
However I got the same parts from International & Ford for quite a bit more (did not know about the kit at the time).
The kit has all of the necessary parts and most importantly, the brush tool which keeps the inner flange from falling into the pan.
It is an easy fix and it works very well.
Drain the oil and remove the starter, the rest is easy to follow. You can do it and it works-no more leaking!
Also:
The o-ring on the inside of the pan swells up for some reason and leaks.
The flange nut on the outside distorts/warps and adds to the problem.
The dipstick o-ring has been revised. It is NOT a standard o-ring as it has a different shape to it.
Do the fix and you will see all of these things.
Old Dec 30, 2010 | 12:35 AM
cowmilker08
I can't take the credit for finding it, 260karl gets the credit.
And I guess I will be the guinea pig for this.
ghunt
Jan 15, 2015 12:36 AM
hammer65
Oct 12, 2012 12:51 PM
cowmilker08
Dec 29, 2010 11:15 AM
mcdev
General Automotive Discussion
Jun 28, 2004 01:08 PM
faroffthetrack
Jun 21, 2004 05:58 PM
