torque converter cover
Old Dec 29, 2010 | 09:24 AM
AndysFords's Avatar
AndysFords
Does anyone know where I can find a Torque converter cover for a 88 Diesel C6? No one seems to have one not even the junkyards around here.
Old Dec 29, 2010 | 10:13 AM
38Chevy454's Avatar
38Chevy454
Is it different than the gas C-6? Or could you modify a gas cover to work? I am completely out of my knowledge here, but seems you could find something to modify?
Old Dec 29, 2010 | 12:30 PM
PLC7.3's Avatar
PLC7.3
Are you sure it is not an E4OD........ C6 has no cover in my schematic.
NOTE..... if the trans has large square aluminum webbing on the outside it is a E4OD
Old Dec 29, 2010 | 04:14 PM
kenpobuck's Avatar
kenpobuck
Yes there is cover/inspection plate on the c6. I have one out in the shed that was on mine before the swap to the t18. It is just a flat steel plate that goes up to the oil pan and down to the bottom of the bell houseing. The bolts that hold it in place are 1/4 or 5/16 I think and the holes are located around the outer edge of the bell houseing.
Old Dec 29, 2010 | 08:57 PM
ford390gashog's Avatar
ford390gashog
The C-6 does have the cover and its held in by 4 bolts. The cover is only unique to the C-6 diesel engine the gas covers will not fit. This reminds me I need one to I ripped mine off on a rock over a year ago.
Old Dec 29, 2010 | 09:01 PM
PLC7.3's Avatar
PLC7.3
OK I concede....... it has a cover............. just not on my schematic.
Old Dec 30, 2010 | 10:00 AM
kenpobuck's Avatar
kenpobuck
That cool PLC7.3... all the books I have don't show one either. My problem is I need one for my t18. Seems everyone around here took them off and none of the yard trucks have one. I am hoping that the spare rig I bought has one on it.
Old Dec 30, 2010 | 12:50 PM
Tech89's Avatar
Tech89
Would a metal shop making you one be a possibility? I would think they could fab one up for you if they had demensions and everything of it.
Just a suggestion.
-Pat
Zazoos
Oct 6, 2016 06:04 PM
filthy6
Oct 21, 2015 11:14 PM
Highboy74
Jun 7, 2012 11:55 PM
JULES-THE-FIRST
1997 - 2003 F150
Mar 5, 2010 03:40 PM
HIGH_N_DRY
1978 - 1996 Big Bronco
Nov 3, 2002 10:06 AM
