Headlight Sytem Wiring
Old Mar 5, 2003 | 02:50 AM
mikebemt's Avatar
mikebemt
I'm a volunteer firefighter and want to put a headlight flasher unit in my 97 F150. To order the correct unit, I need to know if the headlight system utilizes positive or negative switching.
I have no idea what this means or what my truck might have.
Can someone help?
Thanks!
Old Mar 5, 2003 | 11:47 AM
sparky's Avatar
sparky
Most of the trucks I have seen are positive switched, meaning the headlights are grounded to the rad support and the power wires are fed thru the headlight switch. Of course these are all pre-80's trucks
I am unsure of the newer trucks....so maybe a quick call to a Ford Dealer would confirm what you have. I seem to recall that the newer trucks have relays for the lights which could be negatively switched....
Not much help am I
Old Mar 5, 2003 | 01:12 PM
AlM's Avatar
AlM
yo,
Gall says it's + switched; look here for the compatibility chart and more info incl wiring:'
http://www.galls.com/shop/viewProduc...jsp?item=FS003
see:
"Click here for vehicle compatibility" at bottom
