Rear Wiper Fluid
Old Dec 28, 2010 | 12:56 PM
rcosta's Avatar
rcosta
Rear Wiper Fluid
Hi. What would be some of the areas I would need to look at to figure out the winshield wiper fluid was not coming out on the back window? It is a 2000 Excurision. The rear wiper works fine and the fluid does come out on the front window. Thanks so much and happy new year.
Old Dec 28, 2010 | 01:05 PM
wallz's Avatar
wallz
There is a connection under the front passenger foot well. The side plastic panel cover where your fuel shut off switch is. Also one more up high under the back cover(headliner) near the back glass. Check there first.
Old Dec 28, 2010 | 03:34 PM
ukmat71's Avatar
ukmat71
open up your tailgate , pull the plastic surround from off the top.
remove the little plastic round thing (there is a name for it but i cannot think of one for now) from your cloth trim , reach inside , you will almost 99% find your hose has come apart , its about 3-4 inches inside on the right hand side as you look in from the back.
push them back together , job done
this is a very common problem , i have to do mind 2-3 times a year , more if its below zero .
Old Dec 31, 2010 | 10:27 PM
rcosta's Avatar
rcosta
Smile Foot well
Hi,
Thanks. The tube was disconnected by the foot well. You were correct. Thanks for the advice.
Happy New Year.
FLRob
Feb 12, 2014 11:37 PM
vczar1
Mar 24, 2013 12:45 AM
tylerhughes
Oct 10, 2011 11:33 AM
msutton331
Mar 16, 2005 01:02 PM
vyates1
15
Mar 1, 2005 12:32 AM
