no, the only thing that needs to be removed is the crank pulley/dampner. if I can do one in a gravel parking lot with a rented puller/installer. it can't be too hard.
do a search for melling LPOP. duckfan did a great write up on his
Barney
sorry, its been a minute. thanks for the info on the lpop. truck originally died in sprfld, mo. fixed it headed back. the rear high pressure line fitting on the new pump blew out of the body at dexter, mo. took the hpop off and had a machine shop drll it thread it and make a brass insert. which blew out in jackson, tn. trucks still there. i made it back to base in a loaner. some weekend after payday and have the parts shipped in i'll go back and get it.
Not sure which "other" post you're refering to but I just got done instaling the dampner and its a right hand thread. Could they be refering to the fan clutch?
