Valve removal
Old Dec 27, 2010 | 03:12 PM
Georgia Dentside's Avatar
Georgia Dentside
Valve removal
Hey guys, looking for a inexpensive way to remove valves, springs
Old Dec 27, 2010 | 03:15 PM
Georgia Dentside
Its a 460 if that means anything. I work on aircraft and we have a special tool we use, but unfortunately, vehicle engines have no rocker arm shafts on which they fit.
Old Dec 27, 2010 | 03:29 PM
mark a.'s Avatar
mark a.
A quick makeshift way. Put a big nut down on the bench and set the head down on it so it's holding the valve up. Find a bolt and big washer, thread it into the rocker stand. tap the retainer with a brass hammer to loosen the keepers. Put a big pair of channel locks under the bolt/washer and lever the retainer down to remove the keepers.
Old Dec 27, 2010 | 03:45 PM
GLR's Avatar
GLR
With the heads off a "c-clamp" type valve spring compressor is best. A lever type compressor is also available for removing valve springs with heads on (made by KD or Lisle)
tcjhkbjt
Mar 9, 2015 05:06 AM
rugateer
Nov 18, 2014 12:31 PM
Furniture Doctor
Oct 6, 2014 11:03 AM
embry1123
Mar 17, 2010 07:45 PM
Stetch
New Member Introductions
Mar 20, 2007 08:16 PM
